dumb mistake
Old Aug 26, 2009 | 02:22 PM
SD6's Avatar
SD6
dumb mistake
so last night i left my windows slightly open so as not to fog up in the morning on the way to work, but overnight there was a huge THUNDERSTORM!!!! my seats were all soaked, i got out and wiped it down with a towel and dried it up as much as i could, but now there's a weird smell. I'm assuming its the foam under the seat, but do any of you guys know how to get rid of that smell? or does it just go away when it all dries out?
Old Aug 26, 2009 | 02:54 PM
Steen27's Avatar
Wierd smell could be wet leather, carpet, insulation, foam, glue, MOLD, etc. etc.
You're best bet is to try and get things dried out as soon as possible... smell may/may not go away depending on what is causing it... I'd pull the seats out and try and dry them outside the vehicle and see what else got wet inside the vehicle...
Good luck.
Old Aug 26, 2009 | 02:59 PM
Bob_F's Avatar
The important thing it to act quickly. Mold can start growing in as little as 24 hours.
Old Aug 26, 2009 | 05:27 PM
hANDYcaptd's Avatar
It's the Halladay season!
Get that thing dry. Leave your window and moonroof open when its warm and sunny and let it evaporate. A friend of mine had that happen and left it. Now his car smells horrible.
Old Aug 26, 2009 | 06:56 PM
fobstylez's Avatar
I kinda had that problem but it wasnt a huge storm but nonetheless my seats were wet. I dried it off and turned on the seat warmers. Then I sprayed the seat with anti bacteria spray to prevent any mold, that and to help the smell. My SRS light went on, i had to reset the code and it never came back. Everything should be ok now. fyi, in case you want to try that
Old Aug 26, 2009 | 11:47 PM
nhn23's Avatar
I live in
www.weather.com check for the weather next time
Old Aug 26, 2009 | 11:51 PM
SLushhYYY's Avatar
Keep It Simple in
fail......febreze ftw
Old Aug 26, 2009 | 11:59 PM
TouringLow's Avatar
if you know what you're doing. remove the seats and remove the leather and foam. then clean and dry it.
Old Aug 27, 2009 | 12:11 AM
nhn23's Avatar
I live in
atleast we have leather to cover most of the water, my friend's wrx had the same problem, forgot his window down, that night was a big thunderstorm. wasnt smelling good
Old Aug 27, 2009 | 12:19 AM
Edward'TLS's Avatar
6G TLX-S
and the floor linings. It's virtually like gutting out the car.
Old Aug 27, 2009 | 04:54 AM
Rajca's Avatar
wham bam thank you ma'am
^i had to do that before. but mine wasnt that bad. and sucks about ur car.
Old Aug 27, 2009 | 09:22 AM
jzhu625's Avatar
go somewhere with a lot of sun. leave all your windows open, and leave all your door wide open. let the sun do the works.
Old Aug 27, 2009 | 12:16 PM
'03TL-S's Avatar
There could be water in the carpet and under it now. I'd suggest to look into that also.
Old Aug 27, 2009 | 07:18 PM
Acura_TL_02's Avatar
^^lol tht guy
time will get rid of the smell ...
cycdaniel
Dec 17, 2019 10:58 AM
thegipper
Sep 28, 2015 01:01 PM
carz0159
Sep 20, 2015 06:11 PM
Silverstead1
Sep 17, 2015 06:45 AM
