dual-shift problems-please help
Old Jan 19, 2006 | 06:44 PM
jbird727's Avatar
Hey guys,
When I got in my car tonight, I shifted from automatic to standard, and it didn't switch over. The gear shift light didn't come on and it continued in automatic mode, even though it was supposed to be in standard. What happened? How do I fix it? Have any of you experienced this problem? I have an 03 TL-S!
Old Jan 19, 2006 | 06:47 PM
Bambo2888's Avatar
they go wooooot wooooot
wow that sucks. someone help him, im curious to see what it is
Old Jan 20, 2006 | 11:11 AM
acutee's Avatar
when you pulled it over to SS mode, did you see the gear display on the speed panel?
Old Jan 20, 2006 | 11:47 AM
bkzjimmy's Avatar
NiGhT rIdEr
u missed this part...
Originally Posted by jbird727
The gear shift light didn't come !
Old Jan 20, 2006 | 02:47 PM
Edward'TLS's Avatar
6G TLX-S
Hey guys,
Try pull out the power to the PCM to reset everything. If it reappears and won't go away, a trip to the dealership is the only choice.
Old Jan 20, 2006 | 02:50 PM
phipark's Avatar
Not Asian
at calling the SS a standard.
Old Jan 20, 2006 | 02:55 PM
acutee's Avatar
Oops, you got me.
Old Jan 20, 2006 | 05:21 PM
PenancE's Avatar
either someone tried to fuck around wit the ss, ie. reverse shifting mod, and they did a little twist to it....lol
Old Jan 20, 2006 | 07:30 PM
khoifl's Avatar
yea, try to reset your PCM by pulling the harness out if you know where. Or unplug your battery for 15 mins, be prepared for navi and/or HU code.
Old Jan 24, 2006 | 10:06 AM
georgy_d28's Avatar
i actually had this problem, but the d5 light was flashing and it ended up being a part being a part that was relativley inexpensive, less than100 dollars. It was called the something detent bracket but, it was actually a switch thats attached to the assembly, that must be replaced as a unit. i couldnt get a link here but go to the owners website, estore, parts catalog, chassis, select lever, and its #15 and its 74.76
Old Jan 24, 2006 | 11:54 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Hey guys,
Where are you located?
This may not be your problem but I thought I'd share anyway. This comes from the manual:
"If the transmission temperature is below 14F you may not be able to use SportShift"
So if it was extremely cold and you tried using SS when you first started, this could explain it. Otherwise
