Dry and Brittle Valve Cover Gaskets
Old 08-20-2012 | 09:27 AM
deepconcentratn's Avatar
I am doing valve cover gaskets on my Acura 2000 TL and the gaskets are hard to remove. They are breaking and tearing everytime I try to remove them.
Does anyone have any suggestions? Can I soak the valve cover in a solvent with hopes that the gasket will easily peel off.
What can I do?
Old 08-20-2012 | 09:52 AM
dreem1er's Avatar
deal with it
Carb cleaner and razor blade should nicely
Old 08-20-2012 | 10:43 AM
01tl4tl's Avatar
they make actual gasket remover spray which softens and loosens old material
see any parts store
be really careful with razor blade on remnants--any nick in the aluminum can turn into a leak past the new gasket
dont forge to clean the egr port and passage thru the intake manifold while you have it off for valve adjustment
service TB- IACV while its on the bench too
IBankMouse
06-13-2020 12:53 PM
fifer16
1G RL (1996-2004)
10-05-2015 10:12 AM
MilanoRedDashR
09-24-2015 11:04 PM
Quick Reply: Dry and Brittle Valve Cover Gaskets
