DRL warning light
DRL warning light
Hello... does anyone experience the DRL light coming on intermittently? My '02 TL is regularly having the light come on. I can easily force it off by turning on the full head light system. I've heard there is a 'fix' available. Taking to the dealer would be well over $200 I've heard. Any suggestions would be appreciated.
6G TLX-S
Check and see if both high-beam bulbs are still working.
AZ Community Team
Received 7,771 Likes
Welcome aboard North07.
I think you might get more action in Problems and Fixes.
Moved.
Moved.
Just to clarify.. I dont want to disable it. There are lots of posts on how to do that. Here in Canada DRL are mandatory. My problem is the warning light comes on frequently. It always means my DRL's are not on. I can get around it by either turning on the full headlights or switching frequently between lights on/off and flash high beams. Eventually the DRL's will come on and the warning light goes out.
AZ Community Team
Loose connection?
Failed wiring/Frayed wiring?
Bad Fuse?
Bad Bulb?
Bad Fuse?
Bad Bulb?
Shoot me your email will be glad to help.
6G TLX-S
Hi Spiro.. not sure if you got my email but my contact is bgarrod@solutionsmanagement.ca
Forwarded to the one in the post above.
For the benefit of anyone else having the same problem... I was surprised at how cheap the DRL module looked under the dash. It really looked like a low-cost add-on; perhaps to be Canadian law compliant. The 14 pin connector seemed somewhat disjointed from the cheap box that held the module. After repositioning everything the warning light is gone. I will be surprised if it permanently fixed the problem but it's clear that loose connections in this flimsy package could cause problems. If it comes back, I'll do the full voltage tests suggested in the troubleshooting guide. Thanks to all for the responses.
NBP
had the same problem with my accord . if it happens again remove the module, open it and look at the soldered parts you will see 2 burn marks or cracked solder just reheat and it should work ..never had proble again but car is gone now...
rockyboy
01-25-2016 06:00 PM
sockr1
10-01-2015 01:31 AM
