DRL light stays on
Old Nov 26, 2006 | 08:32 PM
Sparks's Avatar
4th Gear
Exclamation DRL light stays on
I just bought a 2002 tl type S on thursday and the DRL (daylight relay) light is staying on, on the dashboard when headlights are off, and due to this I don't have any daylights. Would anyone have an idea on what it could be and what I could do.
Thanks.
Old Nov 27, 2006 | 04:09 AM
MikePA's Avatar
I'd answer, if I could understand your question.
DRL = Daytime Running Lights.
Old Nov 28, 2006 | 08:22 PM
Sparks's Avatar
4th Gear
What I want to know is were is the fuse box or relay located exactly for the daytime lights
Old Nov 28, 2006 | 08:27 PM
fsttyms1's Avatar
Under/behind the passenger side in car fuse panel.
Old Nov 28, 2006 | 09:07 PM
Sparks's Avatar
4th Gear
Drl
Sorry to bother you again, Do you mean under the glove compartment because I looked there and don't see anything that looks like a fuse box.
Thanks for your help.
Old Nov 28, 2006 | 11:46 PM
schmurf's Avatar
As mentioned DRL = Daytime Running Lights. If you have that on your car, it is Canadian and if so you should know about that (you should be in Canada) ... been law for a while now.
One suggestion I have is that if it is not the fuse, it could be the headlamp switch. The one on my 94 Accord EXR went on me recently and I had to replace it. One of the symptoms was that I lost my DRL, though my regular and hi beams were working fine. I also had a problem with the turn signal light not wanting to cooperate.
Good luck with it!
Old Nov 29, 2006 | 09:39 AM
mezzerTL-S's Avatar
New ride...Acura MDX 2013
actually if I'm not mistaken the fuse is in the drivers side fuse panel and for all your fuse box info refer to your owners manual page 300
Old Nov 29, 2006 | 11:24 AM
fsttyms1's Avatar
Yes the fuse is there. There is also a control unit for it.
Oops, i was looking at the wrong illustration. It is on the drivers side.
"Behind drivers dashboard lower cover" is all it says. Its a 14 wire connector and a actual control unit. There is a fuse in the drivers side fuse panel, as well as the under hood fuse panel (fuse 43 &45)
Old Jul 21, 2008 | 08:07 PM
do you , by chance, have a picture or diagram of the controll unit? my drl light stays on all the time. when my full headlights are on then the drl light goes off. if i flash my highbeams then only the passenger side low-beam light comes on. i've already checked the bulbs. they are both fine. i want to chnge the controll unit for the daytime running light but i don't know what i'm looking for.
Old Jul 22, 2008 | 02:19 AM
Edward'TLS's Avatar
6G TLX-S
Sparks, go and check if either or both high beam light bulbs are not blown.
mada51589
Jan 9, 2025 04:40 PM
sockr1
Oct 1, 2015 01:31 AM
Birdflunuggetz
ILX
Sep 14, 2015 07:00 AM
JnC
Sep 11, 2015 06:06 AM
Fadij
Sep 2, 2015 08:31 PM
