Drivers side window regulator help
Old Jul 2, 2011 | 06:25 PM
bwaysteve's Avatar
6th Gear
I have the panel off and see what I have to do.Is it possible to replace the regulator only and use the motor or do these come as a unit.Can't seem to find any online that are without the motor.I have a couple of broken plastic pulleys and a snapped cable in the bottom of the door and not sure if these are part of the motor and can't be replaced.Anyone out there who has done this?I searched the TL forum but did not find anything.
Old Jul 19, 2011 | 12:10 AM
57 Handyman's Avatar
It probably is better to replace the regulator and motor as a unit. If you had a malfunctioning regulator which resulted in broken plastic guides, you likely had some binding that would have put a strain the motor. There's no way to tell when and if the motor will fail; but if it does, you'll have to go through the whole process again.
Save yourself time and aggravation.
Old Jul 19, 2011 | 12:13 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It only comes as a unit.
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
govtcheez
Oct 1, 2015 12:21 AM
hand123
Sep 10, 2015 09:27 AM
ahsm
Sep 9, 2015 08:35 AM
