Driver side mirror tilt not working
Old Feb 22, 2006 | 11:11 AM
srgilbert's Avatar
Hi,
About a month ago the driver side mirror stopped tilting in reverse. The right one works fine and the mirror control switch is centered as it should. The left mirror works fine when using the control to adjust it. All the fuses under the dash are fine from what I see.
ANy ideas? Bad connection in the door or something else?
Old Feb 22, 2006 | 03:29 PM
acurabum's Avatar
Only the passenger side mirror tilt in reverse , never the driver side ?????
Old Feb 22, 2006 | 03:41 PM
phipark's Avatar
Not Asian
^^ well, let's just hope he meant passenger side
If the p side isn't working anymore, try to adjust it up and down. Then move the switch back to center and see if it works.
Old Feb 22, 2006 | 04:24 PM
srgilbert's Avatar
I thought for sure that the driver side and passenger side self adjusted down - are you sur eonly passenger? I have manually and electrically moved the driver side mirror and it doesn't seem to wake up the tilt down feature (if it ever was there)?
Old Feb 23, 2006 | 08:12 AM
TLofNYC's Avatar
Registered Abuser
Only passenger side will automatically tilt....for sure..
Old Feb 23, 2006 | 09:01 AM
pmptx's Avatar
Honda+Blue=My garage
Pass side only-confirmed as I backed out of my garage this morning
Old Feb 23, 2006 | 09:11 AM
fsttyms1's Avatar
Try reading the manual to get positive information
Old Feb 23, 2006 | 09:36 AM
acurabum's Avatar
The driver side mirror will tilt down ( all the way as an error )and stay there if you modify the memory seat position without setting it .....
Old Feb 23, 2006 | 12:06 PM
phipark's Avatar
Not Asian
Oh, nevermind, he was serious.
Old Feb 25, 2006 | 01:18 PM
srgilbert's Avatar
You are absolutely correct. The right side per the owners manual tilts down. Since I recently purchased the car one of the memory buttons had not been programmed and the driver side tilted - anyway - thanks to all - nothing broken and nothing to fix
csmeance
Jan 7, 2026 06:25 PM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
08 NBP TL
Sep 8, 2015 08:49 PM
