Driver side Headlamp?
Recently
I was driving home from work, my Left headlight just turns off by itself while the passenger stays on
What I did is I Turn off the switch and toogle back on and would work but then a few minutes the driver headlight just turns off automatcially
It mostly happens at random times when the temperature drops below 70 MOSTLY
Could it be the fuse?
Or the Oem ballast kit?
Hey TunaTheFish, if ya were not having that problem before you swapped bulbs,
then simply check the effected bulb and socket for a proper fit.
Maybe not making good contact or perhaps the retainer wire isn't on correctly ???
rockyboy
08-04-2024 10:35 AM
BoricuaTL
04-08-2016 01:08 PM
sockr1
10-01-2015 01:31 AM
