Dome Light won't turn on when opening the door
Old Oct 30, 2006 | 02:39 PM
drnozzell's Avatar
3rd Gear
The dome light in my 2002 TL won't come on when I open the door. Yes, the switch is in the center postion and the light will go on manually if I move it to the left. Read somewhere about a multiplexer relay. Went to the dealer and they said it was a door switch. At $5.00 a pop I replaced them all. No luck! Called Acura Corporate and they said that there was no relay and probably a door switch. I'm stumped. Anyone run into the same problem?
Old Oct 30, 2006 | 03:37 PM
fsttyms1's Avatar
Im wondering if the switch itself is bad?
Old Oct 30, 2006 | 04:29 PM
hawnr6's Avatar
I just had the same problem on my TL..
Try taking off the dome light, by taking off the 2 nuts and unclip the wiring harness..
Then carefully pop off the switch and then the copper pieces.. I just got some steel wool and cleaned off some green corrosion that was there.. fixed the problem, works perfectly
peace
Old Oct 30, 2006 | 05:13 PM
Blazin_TL's Avatar
Registered User
I have the same problem, i just tried what hawn said but no luck.
Old Nov 3, 2006 | 09:36 AM
drnozzell's Avatar
3rd Gear
I replaced the dome light and still the same problem. I'm thinking there is a mux or relay that controls the light and dimmer on the interior dome light, even though Acura Corporate says differently. Does anyone have a wiring diagram of these components?
Old Nov 3, 2006 | 01:32 PM
fsttyms1's Avatar
I would talk to the dealer/service department. Its probably controlled by one of the multiplexes then
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
