Do I need a new ballast?
Old Dec 23, 2014 | 02:01 PM
allencosby's Avatar
I have a 2003 TL, and when the lights go on they wil randomly turn off. When I manually turn the lights off and back on they will remain lit for a bit, but will go out again. I have read it may be the ballast. How do I know for sure, and if I need to replace it should I get the conversion kit?
Any suggestions would be appreciated.
Old Dec 23, 2014 | 03:16 PM
3.2TLc's Avatar
Welcome Allencosby !!!
Check the electrical connections and grounds. Inspect for signs of moisture or corrosion.
Our original "HID" low beam headlamps are susceptible to various problems as they get older. The subject has been well documented and tons of info is available by searching previous threads. Check the 2nd Gen's "DIY" sticky for more info. The aftermarket replacement kits are the recommended fix for our old ailing HID set-up. Inexpensive and much more dependable compared to repairing with OEM parts.
Old Dec 24, 2014 | 10:33 AM
01tl4tl's Avatar
contact HID Kits | Conversion Kits | Xenon Headlights | HIDeXtra call them and say acurazine sent you
ask for best coupon code they have (also look online yourself!)
major sale this month of December!!
you want the regular `kit` for your year which contains 2, 35 watt ballast, 2 ignitor/invertors and 2 new bulbs
suggest 5000k color on the bulbs
then see the numerous install threads for easy diy help!
= lighting problem solved!!
Old Dec 24, 2014 | 10:34 AM
01tl4tl's Avatar
do NOT order the relay or other parts- not needed for us
CL-S progression 01
Jan 26, 2016 04:15 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
h22lude
Sep 27, 2015 06:22 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
Juandiablo
Sep 27, 2015 10:32 AM
