diy alternator removal
Old Jan 9, 2013 | 12:46 PM
03c0upe's Avatar
1999 tl
can anyone link me to the diy thread for alternator removal, i swear there was one
Old Jan 9, 2013 | 04:50 PM
3.2TLc's Avatar
Alternator removal.......
Hey 03cOupe, it's actually pretty straight forward.
1) Obviously, ya may want to disconnect the (-) cable from the battery before removing the alternator.
2) Locate the alt's drive belt and remove by taking the pressure off the tensioner pulley.
3) Then take off the electrical connectors and the ground wire retaining nut.
4) Remove the two mounting bolts for the alternator support bracket and then the one behind for the wiring harness.
5) It's a bit tight working, but it'll come out and go back in with some gentle persuasion.
Old Jan 9, 2013 | 05:11 PM
fsttyms1's Avatar
^ you want to disconnect the POSITIVE wire as well. If not there is still 12v going to the alt.
Old Jan 12, 2013 | 01:53 PM
03c0upe's Avatar
1999 tl
When my alternator started going bad the dash lights were flashing, SRS light came on. After replacing the alternator the SRS light remains on. What could be the cause?
Old Jan 12, 2013 | 02:24 PM
jra8858's Avatar
The srs light probaly was triggered by low voltage due to the bad alternator. Dead batteries/alternators usually tend to cause all types of electrical gremlins to pop up.
should be fairly similar
Old Jan 12, 2013 | 05:29 PM
03c0upe's Avatar
1999 tl
http://www.youtube.com/watch?v=4t4ds8ae9tM
thanks it worked
Old Jan 12, 2013 | 05:50 PM
3.2TLc's Avatar
SRS reset
Originally Posted by 03c0upe
thanks it worked
Yeah, and so do your airbags !
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
agupta3224
Sep 22, 2015 08:08 PM
scionxb3003
Sep 22, 2015 05:28 PM
