Dash Warning Lights are on
Old Jun 24, 2006 | 01:24 PM
FoxRC51's Avatar
6th Gear
Hope everyone is enjoying their weekend, well I just did the foglight mod to my 02 TL. Thats fine and works perfectly. However, in doing so, I blew a fuse. I took out most of the fuses behind the dash and in the engine compartment and they were all fine. Then I figured out it was the "small lights" fuse that was blown. I replaced that and all was well again, however, now my TCS, Check Engine, ABS, and SRS dash warning lights are now on. I'm assuming this was caused because I removed most of the fuses. Any suggestions on how to reset them or turn them off (disconnect the battery for a while?). I hope I dont have to make a trip to the dealer.
Thanks in advance for any replies and suggestions.
Old Jun 24, 2006 | 02:07 PM
PenancE's Avatar
d/c the battery, and see if it comes back on....my opinion, some others will say scan it.
Old Jun 24, 2006 | 06:37 PM
FoxRC51's Avatar
6th Gear
Alright, I d/c the battery. Then the lights were still one, except for the check engine light. So, i tried to get out of the driveway, then the ABS and TCS lights went away. However, the SRS light is still on. I went to autozone and there were no codes or anything. So, i guess its time for a trip to the dealer to check the SRS light.
Thanks for your help.
mada51589
Jan 9, 2025 04:40 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Greengecko
Sep 16, 2015 08:19 PM
PortlandRL
Sep 14, 2015 12:01 PM
