Dash lights don't work when the headlights are on
Old Aug 20, 2007 | 12:35 AM
njathlete08's Avatar
9th Gear
hey all,
i just installed an aftermarket radio and now the dash lights don't work when i turn on the lights. i checked all the fuses and they are straight. i read on another thread that i need to ground the illumination wire to get them back in gear after installing an a/m radio.
anyone have a wiring diagram for an 01 tl that would show where the illumination wire is, or have a suggestion on another place to grab the wire without breaking down the armrest/dash again?
Old Aug 20, 2007 | 11:01 AM
9th Gear
bump
Old Aug 20, 2007 | 11:21 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
you shouldn't have to ground anything other than the ground when putting in a new radio....have you checked the fuse to be sure? does the illumination on the radio dim when you turn the headlights on? do the other lights come on? (i.e. - window switches, seat heater switches, etc)
Old Aug 20, 2007 | 12:58 PM
AcuraDreamin's Avatar
2000 Acura TL
hey bro the same thing happened to me. I installed an aftermarket deck myself, and i guess i didnt tape all the loose open wires and something grounded which caused one of my relays to short. Fuses were all good, everything else worked fine. I ended up taking it to some mechanic and he bypassed it for me for 100 bucks. Unfortunately i cant dim or bright the odometer lights, but i guess thats the price i pay for doin it myself. Not sure if thats your problem but it sounds like my exact problem
Old Aug 20, 2007 | 02:57 PM
Bob_F's Avatar
Just as a general caution, be very careful when tap into the existing wiring. You can potentially fry some very expensive electronic modules and even disable your car.
This has happened to other forum members.
So if you get to a point where you're not comfortable with what you're doing, bite the bullet and bring it to a professional.
Good luck!
Bob
Bob
Old Aug 21, 2007 | 02:15 AM
9th Gear
Bob F... so cautious... so cute.
Anyway, fixed the dash lights. I grounded the A19 Wire (lights-on signal), which is the red wire in the factory radio wiring harness. It is directly below A9 (dash-illumination), which is a red/black wire.
At first I tapped into the A9 without grounding it, and suddenly the needles and mileage lights started working... yes, I know that's weird. They went on, off, on so I figure I blew a fuse - it was a 15amp fuse inside the engine compartment fuse box. I can't remember off hand whether it said dash lights or small lights, but it was one of the two grouped between the large fuses (the two are front-back, the other fuses in the compartment are side-to-side).
I grounded the lights-on signal wire (Red, A19), replaced the fuse, and although I can't dim the lights anymore they are working brightly and beautifully.
Thanks for the replies. I hope this helps anyone who runs into a similar problem in the future.
Old Aug 21, 2007 | 05:54 AM
ChairmanMaoSaysRTFM
Old Aug 21, 2007 | 09:16 AM
Bob_F's Avatar
I don't understand that comment.
But thanks for the update and the information on how you corrected the wiring.
Bob
Old Jan 25, 2022 | 10:13 AM
KorzaFox's Avatar
Just need some clarification since I have this same issue. In my service manual A9 and A19 are opposite of how you list them but if Im reading correctly you only grounded the lights on signal and did nothing with the wire for the Dash lights brightness controller?
Old Jan 25, 2022 | 02:16 PM
KorzaFox, the last time Bob_F posted on this forum was 19Aug2015.
He may have moved on from his 1999 TL.
Angelus Noceat
1G TSX Problems & Fixes
Oct 16, 2019 01:01 AM
shareef87
1G TL Problems & Fixes
Jan 11, 2016 02:23 PM
nugget_sauce
2G CL Problems & Fixes
Feb 17, 2014 02:27 AM
vtec22
Dec 10, 2010 04:43 PM
