Damaged ECU?
Old Sep 18, 2007 | 02:16 PM
shogunn's Avatar
Damaged ECU?
I recently had my Check Engine light turn on and I immediately brought in the car to a shop. They reported that the actual ECU (Engine Control Unit) was damaged and it would cost $800 just to replace the unit. The car runs fine from what I can tell as I drive it daily.
From talking to all of my friends, this is the first time they have heard of an ECU going out. I have seen a couple of internet sites that offer to repair the unit for $300. Also, is it possible to buy a used ECU online (Ebay $99) and have it reprogrammed for my car?
If anyone can offer me some advice on what I should do, that would be greatly appreciated. I don't want to fork over $800 knowing there is a much cheaper solution.
Thanks everyone.
Old Sep 18, 2007 | 06:03 PM
Hockeyman's Avatar
slobalt defender
take your car to an autozone so they can read the code, post the code here so we can help you out.
Old Sep 18, 2007 | 06:08 PM
fsttyms1's Avatar
i would get a 2nd opinion.
Old Sep 25, 2007 | 04:22 PM
pgarratt's Avatar
The only time i've seen a computer get fried is when someone jump started a car improperly. But even then, it wouldn't run.
Old Oct 7, 2007 | 05:00 PM
chiarlei's Avatar
Originally Posted by acuratech25
i have some new computers if interested just let me know your vin so i can see which one you need i will sell it to you for 100 shipped
Sorry if I'm hijacking anyones post.
I was wondering if you still have ECU's for sale?
I have been ordering parts for my 2002 TL type S, doing a tranny swap from a 2003 CL S, I dont have the VIN from the 6 sp manual CLS thats on its way. Is the ECU the same for all 6 sp manual CL S's?
Anyway, thats a good price and I'll buy it from you immediatly, if you've got the right one.
Old Oct 7, 2007 | 07:20 PM
fsttyms1's Avatar
Yes all the 03 CL 6speeds use the same ECU
Old Nov 4, 2007 | 03:17 PM
KC99TL's Avatar
5th Gear
Hello,
I have a 1999 Acura TL and would like to know where exactly is the ECU located? I've taken almost the entire dash apart (swapping the stereo) and am yet to find this.
According to my local dealership I need a new ECU to fix a recurring transmission problem at a cost of $994 + tax etc. I'm wondering if this is something I can do myself for much less.
Thanks.
-KC
Old Nov 4, 2007 | 03:20 PM
KC99TL's Avatar
5th Gear
Maybe I should have been more detailed about the problem I'm having... sorry about that I'm new. Basically, if the temperature is below about 60 degrees, the TCS and Engine lights get tripped and the car will not drive. Put it in drive, give it gas, the RPM gauge goes crazy but the car barely crawls if it moves at all (pray you're not on a hill). Thank again.
-KC
Old Nov 4, 2007 | 07:47 PM
fsttyms1's Avatar
The ECU is located on the center tunnel in front of the center console. When the side panels are removed you can see the ecu bolted to the floor from the passenger side. (there is 1 10mm bolt on each side holding it.
If the dealer is correct that that is the problem i wold source a used one and use that. You will have to have the dealer reprogram the key to it to work.
Old Nov 5, 2007 | 12:55 PM
KC99TL's Avatar
5th Gear
Found it, tucked away behind the SRS controller, thanks. Now I can verify the part number before ordering a replacement. Let's hope the dealership doesn't screw up reprogramming the keys. Since they hate me for pointing out that they're incompetent, who knows what they'll do or how much they'll charge.
Ever since they changed my transmission I've been having this new problem. It's been back 6 or 7 times and each time they tell me they don't know what caused it and the car's driving fine now so come and get it... BUT we did notice so and so is due for service, that will be X hundred dollars if you want us to do it now while we still have the car... I tell them no 'cause what good is a car with all new parts that doesn't drive anywhere? They're not even trying to fix my car.
Old Nov 5, 2007 | 01:13 PM
fsttyms1's Avatar
Find a different dealer. contact Acura Client services about your service with them.
Old Nov 5, 2007 | 01:19 PM
KC99TL's Avatar
5th Gear
I called them last Thursday, they said the next closest dealer is about 100 miles away. That explains a lot. But since I know the car will drive when it warms up outside, I may call them and make the drive just the same.
Old Nov 5, 2007 | 03:20 PM
fsttyms1's Avatar
Honda dealers are able to do it as well
Old Nov 8, 2007 | 07:50 PM
KC99TL's Avatar
5th Gear
Got the replacement ECU tonight, got it installed no probs. Thanks a lot for the help. Now I need to have the keys reprogrammed. It turns over but won't start, and the key light on the dash keeps flashing. Hopefully they won't overcharge me for this. I've heard horror stories of customers sometimes paying hundreds of dollars for something I'm sure takes them less than 10 minutes.
Old Nov 8, 2007 | 09:45 PM
fsttyms1's Avatar
My honda dealer charged me something like 45 bucks to reprogram the keys to the new ECU
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
malvothegreat
Sep 29, 2015 12:38 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
