d4 light not working
Old Sep 23, 2006 | 12:59 AM
sojue's Avatar
Question d4 light not working
Please help out here.
I just changed my gauges to Silver reverse indiglo gauges and everything worked out well except D4 light on the gear indicator on the gauge.
All the other lights come on like P, R, N, D3, 2, 1 but D4. What's wrong?
Did I do something wrong when I put the gauges together?
Any response will be very helpful.
I already searched like 5 times but no luck
Old Sep 23, 2006 | 09:44 AM
fsttyms1's Avatar
I would say the bulb got turned in the cluster or it encountered a large enough bump to break the element. Id pull it back out and check/replace teh bulb
Old Sep 23, 2006 | 07:23 PM
sojue's Avatar
so there is a seperate bulb only for D4? cuz all the others are working.
Old Sep 24, 2006 | 10:02 AM
fsttyms1's Avatar
do you have a 99?
Old Sep 25, 2006 | 08:53 AM
sojue's Avatar
yes, i have '99
Old Sep 25, 2006 | 10:01 AM
fsttyms1's Avatar
did you get gauges specifically for the 99,???? If not you have to cut the bars out that seperate the PRND321
Old Sep 25, 2006 | 06:06 PM
sojue's Avatar
I already cut the bars. I don't know why only green D4 light is not working
Old Sep 25, 2006 | 06:50 PM
fsttyms1's Avatar
have you taken the cluster back out and double checked that all teh pins in the harness are straight and not bent over?
Old Sep 26, 2006 | 10:01 AM
sojue's Avatar
you are talking about the 3 harness that connected to the cluster?
Old Sep 26, 2006 | 01:22 PM
fsttyms1's Avatar
yes. the gauges themselves didnt cause the light to go out. Something else did. Now its time to take things out and recheck
Old Sep 26, 2006 | 05:32 PM
sojue's Avatar
How can I check if the bulb got burnt out? I don't see any bulbs for gears.
Old Oct 10, 2006 | 06:17 PM
sojue's Avatar
Does anybody know how to replace/check the bulb inside the gauge cluster?
When I shift the gear to D4, the green light is not on. All the other lights are on like P, R, N, D3, 2, 1.
Old Oct 10, 2006 | 08:26 PM
fsttyms1's Avatar
Take the cluster out and check the bulbs back there
Old Oct 11, 2006 | 09:36 AM
sojue's Avatar
I want to know how T.T.. I can't see that bulb.. Do I have to take the needles off? I asked dealer today, and they said the labor fee is 180 !!!! the price for bulb is only 6 bucks..
total 186. insane.
Old Oct 11, 2006 | 09:39 AM
fsttyms1's Avatar
Its on the back side. You can see all teh bulbs back there. Just remove the gauges again and turn it over and check out the bulbs. They arent hidden.
Old Oct 11, 2006 | 11:39 AM
sojue's Avatar
sorry,,T.T I see only other bulbs like signal light, 6 bubls for maint' required light, and etc.
Is there a diagram for the instrument cluster? I looked at many sites, but I can't see any.
Old Oct 11, 2006 | 01:26 PM
sojue's Avatar
Here is the picture of the back side of cluster. How can I locate the bulbs? I tried to take off that white piece too but couldn't because that white wires are attached to the cluster.
Old Oct 11, 2006 | 01:55 PM
fsttyms1's Avatar
unplug them
Old Oct 11, 2006 | 02:19 PM
sojue's Avatar
I was trying to unplug it, but i don't know how..--;;
Old Oct 11, 2006 | 06:47 PM
fsttyms1's Avatar
just pull. it unplugs on the circut board
Old Oct 13, 2006 | 10:40 AM
sojue's Avatar
I just fixed the problem. The bulb was out. fsttyms1 thanks bro.. you just saved me from spending 186 dollars on dealership.
Old Oct 13, 2006 | 11:04 AM
fsttyms1's Avatar
Always helps to go back and double check and inspect.
mada51589
Jan 9, 2025 04:40 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
