Cruise Control Wont Remain On...
I recently got a 2000 TL, and didn't realize at the time that the cruise control wasn't functional. (Only other problem was some of the dashlights being out, just waiting on the bulbs to get in to fix that...)
The main cruise switch goes in fine, stays indented, and lights up. While at speed (I've tried between 40-70) I then press the set button on the steering wheel control, the Cruise Control light on the console lights up for a second, and if I'm lucky remains on just barely long enough for me to take my foot off the gas. Definitely isn't just the light, as if I take my foot off the gas, I start losing speed.
At this point, the only way to get it to do anything else is to turn the main cruise off and back on, pressing cancel, or braking, do not allow me to re-attempt to set the speed and activate the control.
The radio controls function fine on the wheel, and I took the car into a acura certified mechanic for a quick look over earlier, he checked the fuses and something concerning the brake, but said neither of those were the issue...That check was free. A full diagnostic will run me about $100 an hour, which, I'm trying to avoid if it might be something I can fix myself for less than the diagnostic will cost.
Any ideas? Or should I just set aside the cash, and take it back when I can afford to and have them fix it?
Thanks for the help everyone!
POWER!!
I had a similar cruise control issue.
Here's the easy fix (if it applies).
Open your hood, and check your throttle cable. On the outer part, should be the cable linked to the gas pedal, on the inner part should be the CC cable. Check if it has come loose or disconnected, and simply push it back into its place. If this is the issue you may want to tighten both throttle cables a little bit.
If this does not apply on the throttle body side, open up the box to the left of the engine. I believe it may say "Cruise Control" on it, but I cant remember. Regardless you'll see the cruise control throttle cable going there. Open it up, and see if the cable has come loose from the mechanism. Simply re attach it, and tighten up the cables a bit.
I had both of those things happen with me, also thought it was a fuse or a different issue, it just turned out to be what I just mentioned. Plus this way is free as opposed to paying $100 an hour just to find out that the CC cable popped loose.
EDIT: I'll go see if I can take a decent picture for you.
Nikoziara (02-17-2012)
Chapter Leader (Southeast Region)
I would also check the brake pressure switch. It may not have been adjusted correctly and will cause the cruise control to shut off. It is under the dash right at the break pedal just push the pedal and you will see what I'm talking about
Csmaan- I'll try that tomorrow, thanks, hopefully that will be it!
Stephen- I THINK that's one of the things the mechanic did, I know he said something about the brake, and I watched him doing it, at the time he had crawled into the driver side floor and was doing something by it...still worth taking a look at myself though, so thanks!
POWER!!
you have to remove the 4 small bolts for the plastic engine cover- to access the throttle cables
there has to be a little slack in the cable--tight is not right!
if you live anywhere but Ca.- in the USA, go to a parts store and ask for a code scan--its free
If any for wheel speed sensor come up- thats your cruise problem
may be a simple sensor knocked out of place during a recent brake job,
or worn out--crudded wires etc
advise us on any codes found- write them down
I hardly ever use cruise myself, but taking a 4 hour trip next Friday, kinda hoping to be able to use it then. :P
01tl4tl- Sounds good, I'll take it into autozone tomorrow while I'm at it. I'll check the throttle cables first though just in case it is that easy.
if the cruise cable has broken its `outer retainer wall`of the throttle rotator assembly- you dont want it anywhere near the throttle till its fixed = move the cruise cable away and secure with ziptie
could cause a really bad problem!!
Original Owner / Oct 1998
^^^ Thanks for the pictures, no worries on the first picture (both throttle cables look OK to me, if a little un-lubricated)
Regards the second picture, you need to pop open that black cover (see the clip on the front side?) and take a pic.
The brake pedal switch can be tested by holding it UP (towards the driver's seat) with your foot while engaging the Cruise. If it stays on while you are holding it, either the switch has been kicked out of adjustment or the pedal return spring is weak.
^^ Do this SAFELY, we don't want to loose any 'Ziners accidentally.
POWER!!
^^ Do this SAFELY, we don't want to loose any 'Ziners accidentally.![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
Also the cables are lubed (pictured), you just can't really tell :p.
Fixed!
Going to edit the OP with this info too, if it lets me...
First of, thankyou for all the help everyone, I definitely appreciated it, and it gave me a good idea what I was looking at.
That said, it turns out once I knew where everything was, the only training I needed I learned from the N64.
I checked the cables, they were all on, not too tight, little slack, no issues, all of them looked good. However, I noticed the cable going into the cruise control, and thought "What could it hurt?" I unplugged it, blew out the connectors, and plugged it back in.
I then took it onto the highway, and gave it a try, and sure enough, the cruise control functions perfectly now! I guess there must have been some grit in the connector messing with it!
joflewbyu2
10-08-2015 11:16 AM
adreano17
09-29-2015 08:48 AM
