Cruise Control Problem
Old Jun 23, 2008 | 10:49 AM
JTAbby's Avatar
I have an 2003 TL type S. The cruise control quit working today. The switch on the dash has a green light but the buttons on the sterring wheel don't seem to do anything. Any Idea of what to check? Or What migt be wrong?
Old Jun 23, 2008 | 03:57 PM
fsttyms1's Avatar
Check your brake lights. Do they work?
Old Jun 25, 2008 | 12:24 AM
3.299TL's Avatar
I have the same problem I have a acura tl 99 and the light on dash works and the brake light works too, but the one's on the steering wheel only work somtimes, LOST!
Old Jun 25, 2008 | 01:02 AM
01tl4tl's Avatar
remove the 4 bolts holding the plastic engine cover on- remove cover
look at the throttle assembly- one cable is throttle, the other cruise control
Someone here had the cruise cable somehow jump off its roller (you will see)
and jam with the throttle open ---oooops
Dirt or lack of lubrication or??? wierd things happen
Check out the cables first
Old Jun 25, 2008 | 08:41 AM
Legend2TL's Avatar
AZ Community Team
Two guess, the set/accel switch on the steering wheel is bad or the cable reel (also in the steering wheel is bad). The cable reel is a commutator that provides electrical connection of the air bag, horn, stereo, and cruise control to the steering coloumn.
Old Jun 25, 2008 | 08:43 AM
Legend2TL's Avatar
AZ Community Team
Two more guess (forgot), the brake switch (as others suggested) and the cancel switch both being electrically closed. The brake switch is adjustable on most Acura/Honda's if the switch plunger clearance is not correct.
Old Jun 25, 2008 | 11:38 AM
Trackruner228's Avatar
Mine does that too sometimes. You have to push the brake back upwards with your foot under it. The cruise control switch gets tripped because sometimes the brake pedal sits too low. Try that and see if it works.
Old Jun 25, 2008 | 05:56 PM
01tl4tl's Avatar
I would look at the mounting for your switch runner-
either the return spring is messed up (giant feet???) or the switch itself can get loose, check it out, and stop using the nascar e-brake method of- lift brake pedal with foot lol
Old Jun 25, 2008 | 10:24 PM
totaledTL's Avatar
Had cruise failure on another vehicle once. ECM indicated speed sensor failure. If it was that you would most likely have a chk eng. light w/ code set though.
Old Jun 25, 2008 | 11:50 PM
AZN.M3NACE's Avatar
USDM -> JDM
my cruise control doesnt work at all. idk why, but hopefully i can get this fixed by my insurance company because they are the ones who replaced the cruise control computer =)...
my car was it on the side where the wiperblade control is, AC unit, and cruise control. 12K in damage if you guys wanted to know haha
rockyboy
Aug 4, 2024 10:35 AM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
