Courtesy/Map Lights Not Working!?!?
Old Apr 16, 2007 | 02:57 PM
SBUtypeS's Avatar
DECEPTICON
Exclamation Courtesy/Map Lights Not Working!?!?
Hey Guys,
So I was installing my XM tuner in the sunglass holder today, I went ahead and tapped the power wires for the map lights as power for the unit.....Now none of the courtesy lights in the car work lol....the unit is not tapped into the power supply for the map lights anymore, I checked every fuse b/c there is not one labeled for the courtesy/map lights, even called Acura and they were no help....Everything else is working...
Am I missing something fairly obvious here? I don't see what the problem could be if not a fuse. Help me out here, guys!
Old Apr 16, 2007 | 03:16 PM
MurkyRiversTL's Avatar
COTM Coordinator
your dash lights are working though right?
Did you check the fuse panel on the passenger side in the same location as the driver side. There is a fuse ther for interor lights.
Old Apr 16, 2007 | 03:20 PM
SBUtypeS's Avatar
DECEPTICON
Really?...lol...I didn't know there was a fuse panel on the passengers side - just the one on the drivers side and the one under the hood....and yes the dash/instrument lights are in fact working...going to go and check the other panel now
Old Apr 16, 2007 | 03:22 PM
COTM Coordinator
Cool. I didn't know there was one there either I just made it up....... just kiddin.
Old Apr 16, 2007 | 03:26 PM
COTM Coordinator
this time when you wire it make sure you have a proper gound and diconnect the negative terminal on your battery, cause you might blow your xm tuner.
Old Apr 16, 2007 | 03:27 PM
SBUtypeS's Avatar
DECEPTICON
LOL...that was the culprit...
Another question though, should I replace the 7.5amp fuse for that circuit with a higher amperage one, say 10amps, b/c there will be more drain on that circuit now with the XM unit drawing power as well as the lights?
Old Apr 16, 2007 | 04:06 PM
COTM Coordinator
I dont think so. But Im not sure. If you do want to do that you should check how much amperage is going to the fuse when everything is hiooked up. If its to small it will blow prematurely, if its too big then it will blow something further down the line.
For the guys that hardwired their radar detectors did they use a bigger fuse?
If not then I think you should be ok.
Old Apr 16, 2007 | 04:40 PM
SBUtypeS's Avatar
DECEPTICON
Thanx, Murky...so I've been tooling around for the past hour or so -went to Autozone, bought a bunch of fuses....I don't think I can tap inot the map lights for power. The fuse in the DC adapter that came with the unit is 2amps...the fuse link I installed keeps blowing while drawing power off of this circuit b/c the fuse for the lights is 7.5amps...so I have to run power from an unused circuit in the fuse box and splice-in a 2amp fuse link...I'll post pics and updates tonight or tomorrow when I finish the project.
Old Apr 16, 2007 | 06:31 PM
COTM Coordinator
cool. I'm sure there are many guys who would wanna see a DIY on something like this. You could be a new acurazine hero. Just don't forgt to take pics.
Old Apr 16, 2007 | 06:54 PM
SBUtypeS's Avatar
DECEPTICON
I agree - I'll definitely post a DIY w/pics of the install tomorrow when I finish up. Hopefully it will help out some of the other guys as you said....
mada51589
Jan 9, 2025 04:40 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
