Cooling Fan Control module
You may have had faster luck searching for the 2nd Gen Factory Service Manual, which was a recent topic brought back up in the main 2G Forum. See link https://acurazine.com/forums/second-...manual-946126/. It would be wise for you to keep a copy.
Now, on to the question at hand. The answer seems to be that the [cooling] radiator fan control module is in the center of the dashboard, above the radio.
![](https://cimg3.ibsrv.net/gimg/acurazine.com-vbulletin/1120x2000/20160607_000543_6f5802b72192d8c5ee3c3038549fa277b1e61336.jpg)
![](https://cimg9.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1124/20160607_000602_2f6db75d89fd73f7b8a08866a4c9a4b38a65d9b3.jpg)
As for whether or not you should get rid of your car. He drives one. You might want to keep yours so you can be favored at the golden gates...
![](https://cimg7.ibsrv.net/gimg/acurazine.com-vbulletin/540x338/7570_938127b6d7e3bfc4749133fc23a6163804cff149.jpg)
This is good stuff. Thanks once again. Before I go tearing my dash apart, ( am not looking forward to that). I should get your opinion on what the problem really is.
Neither fan comes on when expected. I can drive for an hour sometimes before the overheat occurs and the radiator fan will not come on. The gauge goes to half way but some times to 3/4. If I keep the heat on high it seems to stay at half. Sometimes after shut down the fan runs for about 10 minutes. Both fans work when the A/C is on.
I have replaced the fan switch, temp sensor, thermostat, radiator cap, fan and condenser relays, coolant and hoses. The only other thing I can think of is the fan control module.
Thanks in advance.
Thanks in advance.
