Compressor sounding noise(not abs)
Old Jun 9, 2009 | 11:54 AM
kidduce's Avatar
So I just started noticing this noise about a month ago, its a little hard to explain but the noise sounds like its a compressor rattleing sound. I opened the hood and heard it below the timing belt, its weird because it is not consistent, it will do it when its cold being specific when I turn it on to go to work and when im going home from work, or when it sits for a while. The noise usually starts for about 10 sec. then go off and comes back on for 3 sec. then off again and back on for 5 sec. Very inconsistant.
The car has close to 92k and ahavnt had any of the belt or pump services. Any one have a clue of what this could be? Is something gettting ready to give out. Thanks guys.
Old Jun 9, 2009 | 12:15 PM
fsttyms1's Avatar
Cant really say for sure with your description but possibly the belt tensioner
Old Jun 9, 2009 | 12:18 PM
hANDYcaptd's Avatar
It's the Halladay season!
Is it loud enough that you can make a quick video of it? That may help.
Old Jun 9, 2009 | 12:20 PM
kidduce's Avatar
Ya horrible description I know lol. Really it does it when its been sitting for some hrs, on the way to work it was doing it when I got there 20 mile commute. Are those pricey>?
Old Jun 9, 2009 | 03:02 PM
kidduce's Avatar
Now that I remember, when in idle and I rev up to about 2k it makes the noise, so it is responsive with throttle response.
Old Jun 11, 2009 | 01:30 PM
kidduce's Avatar
Would I damage anything if the tensioner was going bad and I left it like this for some more miles?
Old Jun 11, 2009 | 01:56 PM
hANDYcaptd's Avatar
Well if the tensioner goes bad and belt get too much slack, alternator and AC compressor pulley could slip, which is bad. But I doubt the tensioner will give way all of a sudden. Should be more of a progressive failure.
Old Jun 11, 2009 | 02:07 PM
kidduce's Avatar
Hmm, sounds like its time to make plans for the 100k service then.
Old Jun 11, 2009 | 02:13 PM
hANDYcaptd's Avatar
Wait, were you talking about the timing belt tensioner?
I was talking about the serpentine belt tensioner.
Old Jun 11, 2009 | 02:48 PM
kidduce's Avatar
Either one I guess, real noob here. Im pretty sure I dnt want either one to snap on me or break.
Old Jun 11, 2009 | 02:49 PM
kidduce's Avatar
Ive herd from techs that tensioners make noise when going bad and sometimes after they warm up the noise fades away. It used to do it now its more constant the noise is.
Old Jun 11, 2009 | 08:50 PM
hANDYcaptd's Avatar
If the noise goes away after it gets warm, I'd suspect the tensioner pulley. It's a very easy replacement.
But if you're getting the 105k soon, have them check it out
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
kixo
Sep 25, 2015 03:07 PM
