Compatible oil pan?
Compatible oil pan?
Will an 02 TL oil pan fit a 99 TL? have a 02 in a salvage yard with a good pan, but I need to verify it will fit a 99 before I pull the trigger. thanks all
They are different, but it might work. The 02 pan is deeper. If you put an 01 pan on an 02, the pump pick up is so close to the bottom of the pan that it won't pump oil. Personally, I wouldn't risk it unless I knew for sure what other pieces had to be changed to make it work.
IBankMouse
06-13-2020 12:53 PM
adreano17
09-29-2015 08:48 AM
