cold shifting
Old Mar 4, 2009 | 03:45 PM
2ndgentl's Avatar
cold shifting
I have 99 tl, why is it that when the car is not warmed up yet (the first 5-10 min. of driving) there is a longer delay in the shifting? UP or DOWN, and sometimes it hits a little harder into gear when the delay is at a certain rpm. I mean I know a lot of you will say "tranny is going," but it almost seems like its electrical. If it is electrical what adjusts the shifting? Or is it ALL done by the ECU and there is nothing you can do?
Old Mar 4, 2009 | 04:50 PM
fsttyms1's Avatar
Nothing you can do. Its all done by the ECU. WHen was the last time you changed your fluid..
Old Mar 4, 2009 | 04:53 PM
01tl4tl's Avatar
on my 01 its part of the engine warm up system to hold the trans slightly higher rpm in 1 and 2 to make the engine heat quickly, then it can get off the full rich start mode for the fuel injection and go into lean economy mode
Should only take a few minutes to get temp indicated, and the system is off cold start
Old Mar 4, 2009 | 05:00 PM
niju321's Avatar
the manual says that harder and delayed shifting is normal until the car warms up.
Old Mar 4, 2009 | 07:53 PM
Luke7's Avatar
WNC Real Estate Sales99TL
Also the Torque Converter won't lock up until the engine is warmed up.
Old Nov 3, 2009 | 12:27 PM
Kobazi's Avatar
What happens when the car is warmed up
Although my car is warmed up the shifting from park to drive is hard and sometimes the car wont kick into gear.
I changed the trany last year and the fluid (level is good) as well. What else could be the problem?
Old Nov 3, 2009 | 01:23 PM
fsttyms1's Avatar
solenoids, trans failing again.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
Hines57
Sep 24, 2015 01:58 PM
