CODE P0740 and P1739
Old Aug 15, 2011 | 04:19 PM
falconsman's Avatar
I just had new motor and transmission mounts installed and after driving the car 20 miles I get these two codes.
The TL still runs like a champ so could it be possible the shop forgot to or even disconnected a sensor by mistake.
Or in the process of changing the mounts they damaged something?
Thanks all
Old Aug 15, 2011 | 04:56 PM
fsttyms1's Avatar
Those are both trans problem codes. Neither of which could be caused by motor and trans mount changing.
Old Aug 15, 2011 | 06:15 PM
mugenspire's Avatar
3 pedals in my 99 TL
This.
I just got the same P0740 code yesterday for the Torque Converter. Hello 6 spd swap.
Old Aug 15, 2011 | 07:25 PM
falconsman's Avatar
Well not what I wanted to hear but could it be as simple as replacing the TCC solenoid (if that is simple) and a third clutch pressure switch (If that is simple as well)have no real clue as to what they are.
Old Aug 15, 2011 | 08:19 PM
01tl4tl's Avatar
thats why we have a DIY section,,, filled with how to replace most of the TL
they may have caused false codes disconnecting a wire or something stupid like that
reset ecu by pulling the clock fuse - on passenger end of dash for a minute
drive it and see if codes come back
Old Aug 18, 2011 | 11:00 PM
BN3DC2's Avatar
i had the same problem..the check engine light pop out and after checking the code and found what it is..i decided to take a look at it by taking off the battery and unplug the 2 wires that connected to torque converter solenoid, then putting back everything in place...when i started the car the light came off..but i still need to take that solenoid out and check the gasket soon..
TypeS860
Jan 10, 2026 11:11 AM
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
