cluster problems
cluster problems
I did open the cluster to clear the gauges and did not remove the needle from the gauge. When i turn the key the gauges are off I know the rpm needle moves when I give gas and I'm sure the mph moves. I just want to know if anyone knows how to get the needles where they are supose to be? Like mph is at 20 when i turn the key.
Oh and be CAREFUL pulling them off and don't push them on too far either as they will hang up
I pulled the tac needles out but used needle nose pliers to hold the gauge needle in cause I seen a video and the guy said if the need comes out you better just buy a new gauge. I made sure to keep the needle in place.
I ended up buying a used cluster on ebay. I got my mph to work but all the other gauges are just done not working right. Im so frustrated but i don't drive my car alot so it really doesn't bother me too much. Idk if i want to change the new cluster im getting with blue reverse glow gauges. Any tips for doing it without messing up this one?
Check fuses and connections. There has been some other past threads on this if you attempt to "search" a bit !
I will figure it out. Like i said its not a big deal Igot the new one on the way if I plug it up and it works fine then I know all connections are good also any fuses that I may have over looked.
What doesnt work right with them? Did the center needle come out? Is the needle on to tight?
the lil needle that keeps the tax needle from going that way fell so I just have to put it back in but that's the only movement I get from the rpm gauge when I floor it.
SidhuSaaB
05-30-2020 12:40 AM
