Cluster lights out and no fog lights?
Wired up my new fog lights lastnite when everything was done i tested the lights on the road on/off worked fine then my cluster light turned off also my fogs. I read somewhere it could be the cluster ground. Don't know where that is also all fuses are fine.
No power to the port with the red wire.(Fogs)
Big Thanks 2 pianoman41 from , I found this just posting for anyone else who might have this problem.
pianoman41
There's another fuse that controls all that in the fusebox located under the hood at the center rear of the engine bay, right up against the firewall. I forget the number but they're labeled. I guarantee you it's that one.
__________________
joepenora
Bro, that was it, I can't thank you enough, I was only looking at the fuses on the drivers side door area.
I had to go through each one acura labeled that fuse "small lights".
If you're ever in New York I owe you a beer.
pianoman41
__________________
joepenora
also check fuses. fuses will blow if they are shortages in power surges and etc I advise you check fuse by fuse to see if any are blown. could be something simple you might be over looking. If you think it has something to do with the fogs then see if you see any electrical weakness like exposed wires or etc
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
