Clock Backlight?
Old May 11, 2011 | 02:11 AM
iamteeg's Avatar
Clock Backlight?
Hi
Just got a 2002 TL 3.2 Type-S, love it! The only thing I have found wrong is that the backlight on the clock is out. Is that a matter of replacing the LED on it? The clock works fine, I just can't see it at night.
If it is a matter of replacing the light, how hard is it to replace the light? Does it require soldering or anything?
Thanks,
iamteeg
Old May 11, 2011 | 04:04 AM
02TL4ATL's Avatar
theres a diy on how to replace the bulb in the diy section
Old May 13, 2011 | 06:38 AM
LaLaBanks504's Avatar
Im having the same problem with the same model car. I was wondering if the clock suppose to have a backlight. Thanks !!!
Old Sep 10, 2011 | 10:36 AM
superjoss's Avatar
yes the clock ilumminates at night the bulb costs $5.00 at the dealer you need to remove the dashboard to replace it.
Old Sep 12, 2011 | 06:53 AM
totaledTL's Avatar
You don't have to remove the dash. It's not too bad.
Old Sep 12, 2011 | 04:56 PM
timberland73's Avatar
99 TLS6 08 TL
Dashboard removal is not necessary. Remove the two screws above the instrument cluster and go from there. Very easy to do.
Old Nov 8, 2011 | 11:48 PM
Airbus380CAPT's Avatar
In my 1999 Acura TL 3.2 someone on the blog suggested hitting the clock or around it will likely make it go back on. I tried it and it worked. Also, the same trick worked for the gear shifter lights. Now I need to find out how to get my parking brake indicator light to be fixed. Anyone?
Old Nov 9, 2011 | 12:33 PM
KatabaticSaint's Avatar
Yeah mine was out for 2 or 3 years. Then i hit a huge bump in the road, HARD thankfully on my stockies and my clock and my D5 light worked again immediately so try hitting it first.
Old Nov 28, 2011 | 06:53 PM
Yumster888's Avatar
I love that I came here to find out about my suddenly dark shifter lights and the basic advice is to just hit it. Will try that.
Old Sep 24, 2014 | 08:40 PM
MikeND's Avatar
Astonishingly, moderately striking the dashboard directly above the clock on my '99 TL made the backlight work again after it went out about two weeks ago - been working perfectly for 10 days now. Last summer I also replaced ~ 6 instrument panel lights after removing the instrument cluster - also replaced the electronic module that displays the gear selected in the sport shift mode. In the last month or so I have noticed the speedo backlight has been dim on the left and top side of the gauge. Figured why not try the strike the dashboard approach again - amazingly it worked with one thump on the dash directly above the speedo - the lights came back on instantly and have stayed on (when the headlights are turned on only - that is when the backlights are activated). Never thought I would be posting this to fix multiple backlight issues - but it works!
Skirmich
Oct 1, 2015 12:59 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 23, 2015 01:03 PM
95legend6speed
Sep 21, 2015 06:40 PM
