Climate Control Problems.
Old Jun 4, 2008 | 02:41 PM
assassin004's Avatar
8th Gear
Can some please give me some advice as to what I should do...
My climate control system is not working properly:
1) The blower does not work.
2) The A/C compressor is not responding.
3) The rear windsheild de-fogger does not work.
However, when I drive at high speeds I can feel some air comming through the vents and if I change the temperature from warm to cold I can feel the difference. I think it is a fuse but I can't pinpoint the problem. I don't want to pay the dealer a boat load of cash for a simple problem. Does anyone have any advice?
Thanks in advance,
Assassin004
Old Jun 4, 2008 | 02:57 PM
Trackruner228's Avatar
Sounds like your AC is busted. The air coming through your vents is normal at high speeds. My AC works fine but if I turn it off at high speeds I can still feel air coming through; thats normal. It might be a fuse but the air coming through is normal and happens even when the AC is working fine.
Old Jun 4, 2008 | 06:16 PM
8th Gear
So what should I do about the "blower" not working. And how can I figure out which fuse it is?
Old Jun 4, 2008 | 06:48 PM
01tl4tl's Avatar
look in the markings on the fuse box covers or read the owner manual for fuse locations
A lot of TLs have a problem with the blower motor electrical connector failure or the resistor on the back of the blower goes out
You remove the glovebox to reach it
See DIY on Change Cabin Air Filter for procedure
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
