clanking noise front left
Old Jul 27, 2005 | 07:46 AM
Iggy's Avatar
I have a strange metal on metal clanking noise that happens only when braking at slow speeds and then again when accelerating from a stop. It almost seems like the brake pads shifting in the calipers, but I have inspected them 3 times and found no evidence if movement. Also when I hit bump while braking the noise will happen.
I do have Comptech sways, but the front seems okay.
I have looked around under the front left several times and found nothing abnormal. Maybe I'm looking in the wrong place. The noise is progressively getting worse with time.
Any ideas?
Thanks,
Iggy
'02 TL-s 75k miles
Old Jul 27, 2005 | 09:12 AM
ilandaze's Avatar
does it sound almost like a poppin metal sound right under the driverside cuz same like me i thought it was my engin mount goin out but it was that the bolt end of the sway bar was loose. it make look find and dande but wat u got to do is torque down everything dat u installed yourself.
Old Jul 27, 2005 | 10:44 AM
progz's Avatar
I got the same problem on my 99TL and I had my rotors and pads replaced. It turned out that the pads were installed the wrong way. One of the pads have a metal thingy sticking (i don't what it is called) but it should have been installed at the back side of the caliper. It was installed in the front side that's why I hear a clanking noise (front driver side) every time I hit the brake. Like you said, I do hear it also when braking on low speed and specially when you're near a wall. Now I don't hear it anymore.
Old Jul 29, 2005 | 11:22 PM
Iggy's Avatar
Thanks guys,
I have checked and double checked everything with no luck!
Man this noise is driving me NUTS. I'm on my third tranny, is it possibly axle tranny related?
Iggy
Old Jul 30, 2005 | 01:15 AM
acrite's Avatar
i know u said u checked your anti sway bar but double check the linkage. i had a similar noise that got progressivly worse. i double checked a thousand times over befor i relized that it was the front left anti sway bar linkage that had worn and eventually broke loose from the mount. (the linkage that connects the the anti sway bar to the lower a arm) hope u get it fixed
Old Jul 31, 2005 | 06:37 PM
TunedTL's Avatar
Initial D
How do you check the end link, I have the same clunk sound when making a big slow right turn - a metal on metal popping sound. Sometimes I can feel the pop from the brake pad. Double checked and re-torque CT sway bar - no luck.
Old Aug 4, 2005 | 06:43 PM
TunedTL's Avatar
Initial D
I found out that my CT bracket is loose and swaybar was hitting the frame. Tighten all four bolts on brackets and the clunk is gone. The best solution acccording to CT is to use self locking bolts.
Old Aug 14, 2005 | 09:27 PM
PenancE's Avatar
wait, the front sway bars have to be torqued? mine is doin the clankin sound too, same symptoms, stop n go. i tightened em, but still doin it, not as hard tho..
Old Aug 15, 2005 | 12:18 AM
HotBoyinDaAcura's Avatar
wait...you installed those didnt you, so sounds like you messed something up on your perfect never been worked on by anyone else TL... Oh yea neon lights are ugly and i just got my TL-S a few months ago and im not gonna make it look like a toyota scion but have fun with the fast and the furious look that was cool 4 years ago johnny chan
Old Aug 15, 2005 | 12:45 AM
TunedTL's Avatar
Initial D
See this thread Tightening Sway Brackets
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
08 NBP TL
Sep 8, 2015 08:49 PM
jliu6789
Sep 8, 2015 08:02 PM
