check engine & SRS?????
Old May 14, 2011 | 08:31 PM
02TyPe_S_Tl's Avatar
Question check engine & SRS?????
SRS light came on and check engine after I rewired my sidemarkers and blew out my small light fuse...so but I did replace it but when I was looking for that fuse I pulled out the turn light fuse when the key was turned to on but the car wasn't on then I went to o'riellys and erased the check engine light but didn't seem to take the srs light off how can I take the srs off???? And what does srs mean?
Old May 14, 2011 | 09:36 PM
totaledTL's Avatar
SRS = Supplemental Restraint System
Do you have an owner's manual?
See the DIY sticky for a video about resetting it: https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
If it comes back on take it to the dealer for a scan as the airbags won't deploy.
Old May 14, 2011 | 10:02 PM
No i do not have the manual didnt come with the car and its 115 for just a diagnose but isnt that for a civic would it still be the same for a acura? and thanx for the help bro
Old May 14, 2011 | 10:06 PM
thelastaspec's Avatar
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
try the video first.
these era hondas have sketchy SRS systems.
you can also try disconnecting the battery for a while and see if stuff resets.
Make sure you have the radio code for when you re-connect the power.
Old May 14, 2011 | 10:12 PM
totaledTL's Avatar
Same procedure to reset the SRS light. It isn't hard.
Old May 14, 2011 | 10:17 PM
yea op, all you need is a paper clip and 5 minutes.
Old May 15, 2011 | 01:28 AM
O alrite thanx guys
Old May 15, 2011 | 10:39 AM
01tl4tl's Avatar
since you were working on electrical there is a good chance its a false light
reset per our procedure here in the diy section
https://acurazine.com/forums/showthread.php?t=706083
If it comes back on- there is a real problem- we have a special 10 year 150kmiles srs warranty that covers most of the parts that fail
worth a trip to acura
all others: if you get SRS red light and have not been working on the car= proceed to dealer,,you have no airbags while red light is ON
Old May 15, 2011 | 10:40 AM
01tl4tl's Avatar
register here as owner and you can access the owner book online for free
http://owners.acura.com/registration...istration.aspx
Old May 15, 2011 | 01:28 PM
I see two yellow connections pluged in like that next to each other which one
is it
Old May 15, 2011 | 02:02 PM
nvm I got it it's off now
Old May 15, 2011 | 05:59 PM
Karanx7's Avatar
Unregistered Member
Yea, it's plugged into nothing. Just a fake switch. Kind of a funny place to "hide" it lol.
Reminds me of the "clock backup" fuse.
Old May 15, 2011 | 09:08 PM
01tl4tl's Avatar
thats `ECU secret backup power is the Clock fuse`
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
