Check Engine or O2 censor?
Old 06-27-2007 | 10:57 AM
ACuRaTeeYeLL's Avatar
awW sHiEt
my check engine light came on after i put in my k&n filter.....i also swiss cheesed my airbox....is this the cause my check engine light to came on?? cause other than that, my car is runnin 115K strong!!
Old 06-27-2007 | 01:44 PM
fsttyms1's Avatar
We have no idea. Did you pull off a sensor while doing this? Bring the car into a autozone and get the codes read
Old 06-29-2007 | 09:17 AM
awW sHiEt
i have someone that could do that but i just wanted to see if i could get a second opinion. thanks anyway
Old 06-29-2007 | 10:21 AM
fsttyms1's Avatar
putting the filter in wouldnt cause it. either its a big coincidence that it came on just after or you happend to damage a sensor or accidentally unplugged something. Reinspect every thing under the hood and look. Also unplug the "clock backup" fuse on the passengerside dash fuse panel for 10 min then replug it in. that will reset the ECU and clear the code. If ti comes back on there is a problem
Old 07-01-2007 | 11:56 PM
awW sHiEt
ill try that...thx
Yikes
05-03-2021 04:29 PM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
Quick Reply: Check Engine or O2 censor?
