Check engine light and tcs light problem on my 2000 acura tl
Old Jul 8, 2023 | 02:49 AM
Ace2000's Avatar
Hello I am having trouble with fixing check engine light code p0131 on my 2000 acura tl. I have replaced the sensor a couple months ago. Recently it has come back and makes my tcs light come on as well I have tried to erase the code and check the sensor but it will come back on. As for the tcs light it goes away after being turned off and then both come back on. Any help with help if you can leave images of locations or diagram that will help.
Old Jul 8, 2023 | 01:27 PM
Here's a download link to the 2G TL service manual.
It will empower you, with all its images and diagrams, to diagnose and fix any issue your car may present:
!!!!!!!!ACURA 99-03 TL SERVICE MANUAL.pdf (dropbox.com)
Good Luck.
Old Jul 8, 2023 | 03:25 PM
Jon M's Avatar
Check page 11-109 in the manual for troubleshooting the P0131 code. The TCS gets an input for speed, if the O2 sensor is bad the PCM could be misinterpreting the input causing the TCS to turn off and the light to come on.
What brand and part number did you use when you replaced one of the O2 sensors? Did you replace both sensors, if not which one did you replace?
acurajoey
Mar 23, 2017 06:30 PM
johnny14
May 22, 2015 10:58 AM
labron23
1G TL Problems & Fixes
Oct 13, 2010 07:08 PM
tst32tl
Jul 21, 2009 10:56 AM
manual123
Dec 12, 2005 08:36 AM
