Change PCV?
Old Jan 15, 2011 | 07:41 PM
kvan2007's Avatar
Change PCV?
Our TL 3.2 has 98k & change on it, and things are good—idle could be a touch smoother, but overall, we've kept it up well. But I'm wondering if I should, just for good measure, change out the PCV valve. It's inexpensive and seems easy enough to do. I welcome input. Gracias!
Old Jan 15, 2011 | 08:33 PM
01tl4tl's Avatar
seafoam-gas and Master vac port
clean the TB air plate, spark plugs- NGK Iridium IX, air filter clean?
pull the intake manifold off and clean EGR passages and ports- that messes with idle and clogs up every 75kmiles
With that job, also do the IACV idle air control- inside the bottem of the TB unit
It gets clogged/sticky and causes idle probs-revving probs at idle etc
if the pcv part shakes ok- spray some cleaner thru it and reuse
thats not a big prob on TL , egr clog much more common
Old Jan 15, 2011 | 11:23 PM
kvan2007's Avatar
Did most all of those things. Thanks.
Old Jan 15, 2011 | 11:44 PM
friesm2000's Avatar
B A N N E D
you and seafoam again lol
but yes EGR clogging is more of an issue then the pcv on our cars
Old Jan 16, 2011 | 03:10 AM
01tl4tl's Avatar
ok just for fries: bg44,seafoam, honda top end cleaner etc are all excellent ways to get the same basic end result = clean parts
Use of something is better than nothing
Old Jan 16, 2011 | 10:13 AM
friesm2000's Avatar
B A N N E D
bg 44k is a fuel system additive, not a "top end" cleaner, they have a seperate cleaner for that
Old Jan 16, 2011 | 11:21 AM
01tl4tl's Avatar
I was giving a few examples for different makers of quality product
You agree bg makes the right products- and their ad pops up all the time
at the mention of s-foam~
the honda T/E cleaner I saw-- was at their motorcycle shop!
lucas is a fuel additive that list itself as TE as well
Users want more info can use internet~
where do we draw the line on petty bickering fries??
mada51589
Jan 9, 2025 04:40 PM
vpasla1
Sep 17, 2016 07:24 PM
datadr
Sep 12, 2015 09:12 PM
Aleax
Sep 11, 2015 11:31 AM
sputik
Sep 7, 2015 01:40 PM
