CEL & TCS lights on 1999 3.2tl
Old Dec 2, 2006 | 07:18 PM
mjb2112's Avatar
I recently purchased a 1999 3.2tl, it has 88k miles. The CEL light has come on, I took it to autozone, they pulled the codes PO 1491 (manufacturer aux emissions) and PO 420 (catalytic converter). I've searched for those codes and found 1 thread for 1491 and nothing for the 420 code.
The TCS light also comes on consistently after the car has been in gear for around 90 seconds. It is driving fine, the only change I've noticed is a rattle sound when I first start the car and it's cold, this sound goes away when warmed up.
I've recently got a new set of tires that roughly coincided to the TCS light coming on.
I'm looking for any advice as to how to proceed and not blow a lot of money at the dealership. Thanks
Old Dec 2, 2006 | 07:22 PM
gc86's Avatar
Advance
You need a new cat, get one cheap off ebay or get a high-flow cat from our vender Excelerate.
Old Dec 2, 2006 | 10:21 PM
Lawaia's Avatar
Moderator Alumnus
The rattling sound, like rocks in a coffee can is a tell tale sign that your cats are bad. Crawl under the car and whack the cat with a rubber mallet; pretty sure you'll here the same noise.
BTW - Welcome to Acurazine.
:moved to Problem & Fixes:
Old Dec 9, 2006 | 07:30 PM
Hot Boi's Avatar
Grippin' Grain
Does anyone know if the P0420 code would make these lights stay on whenever I use the remote start from my alarm. Just curious b/c I never had this problem till I had this code show up.
Yikes
May 3, 2021 04:29 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Allen_442
Sep 8, 2015 06:01 PM
