Car turned off while driving..
Old Dec 8, 2006 | 05:17 PM
03c0upe's Avatar
1999 tl
i was driving along and my car suddenly turned off...this happend before when i tried to start it ..it didnt start on the first turn....now it turned off while driving..it did start up again ....What do guys think is wrong..im at 100,000 KM
Old Dec 8, 2006 | 06:32 PM
Bob_F's Avatar
It could be caused by many different things.
here's an easy one to check. Do you have another Honda or Acura key on your keyring? If so, another key with the built-in immobilizer feature can interfere with your ignition system. There is a caution about this in the TL owner's manual.
I had stalling problems with my 1999 TL until I removed a Honda key from my key ring.
Bob
Old Dec 8, 2006 | 06:42 PM
03c0upe's Avatar
1999 tl
ive been readin it could be the IACV or ignition switch...when i start or turn of my car its not as smooth... do i need one of those replaced? or spark plugs
Old Dec 8, 2006 | 07:08 PM
Bob_F's Avatar
Yes, the Idle Air Control Valve (IACV) can cause this problem. But you wouldn't normally need to replace it. You would instead clean it since the valve can get sticky, There's a great thread somewhere on Acurazine on how to do this yourself but it is a little bit involved. I had my mechanic clean this when I was trying to track down the stalling problem on my TL.
The ignition switch is another possibility. There was actually a recall on the ignition switch for the second generation TLs. My 1999 TL had this replaced before I purchased it. If you're not the original owner of your car, you can call Acura or check the Owner Link to see if your car is covered by the recall.
Spark plugs can be another possibility.
Bob
Old Dec 8, 2006 | 07:18 PM
03c0upe's Avatar
1999 tl
I did call the Acura dealership with my VIN they said theres is no recall for my car..if i call a someplace else or not?
Old Dec 8, 2006 | 07:29 PM
Bob_F's Avatar
The dealer should have access to that information. YOu can also call a toll-free national Acura number to check on that. Another option is to register your car online with Acura to check on all the recall items.
Bob
Old Dec 8, 2006 | 09:02 PM
03c0upe's Avatar
1999 tl
where can i register or get the #?
Old Dec 9, 2006 | 12:00 AM
03c0upe's Avatar
1999 tl
So if my car doesnt start the first time i turn it..it could be the ignition switch?
Old Dec 9, 2006 | 01:12 AM
Bob_F's Avatar
Here's where you can register your Acura online:
https://www.ahm-ownerlink.com/user_profile.asp
And this is contact info from Acura.com:
BY PHONE
Monday through Friday, 6:00 AM to 5:00 PM Pacific Standard time at the toll-free number (800) 382-2238
Bob
Old Dec 9, 2006 | 01:16 AM
Bob_F's Avatar
Yes, it's a possibility.
Here's another thing to look for. If the car doesn't start initially, look for the flashing green key symbol on the dash. If you see that, it might indicate that the immobilizer system is preventing the car from starting.
Good Luck!
Bob
Old Dec 9, 2006 | 02:06 AM
03c0upe's Avatar
1999 tl
well the car wouldnt start i had to leave it at work...its pissing me off..it wont start at all
Old Dec 9, 2006 | 02:20 AM
03c0upe's Avatar
1999 tl
Good Luck!
Bob
my dad did see that green symbol...why cant i start the car? i only have the key and the remote for that car in the key chain
Old Dec 9, 2006 | 09:08 AM
Bob_F's Avatar
the immobilizer keys can be damaged if they get wet or if they get too hot. It might be that your key is acting up. You might want to get a replacement and try that since it's not a bad idea to have a spare anyway. But be aware that the keys are not cheap and that you may need to get it from an Acura dealership.
Search the forum for "spare key" for more information.
Bob
Old Dec 9, 2006 | 02:51 PM
03c0upe's Avatar
1999 tl
well i know its not the immobilizer i got the car started if i hold the key ..i towed it to the mech..seems like it has the symtoms of a igntion switch failure...once the ignition switch gets replaced do i need a new set of keys or anything?
Old Dec 10, 2006 | 02:39 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
What year is this car? If it is a 1999 they had some ignition switch recalls, you might be covered for free. They symptoms of that were the car stalling while driving.
Old Dec 10, 2006 | 04:10 AM
03c0upe's Avatar
1999 tl
i do have a 99 it did stall while driving..and now it wont start at all unless i hold the ignition key at start postion ..i called my local dealer and said im not covered..mechanic so far cant diagose the problem..i crank the key power windows dont work..guessing it is the ignition switch...i need more info on what i need to replace..the whole switch or part of it? one part is 300 and other is 90$
Old Dec 10, 2006 | 09:28 AM
superfob's Avatar
Call a different dealer.
Old Dec 10, 2006 | 12:35 PM
03CoupeV6's Avatar
Register with owner link and that will tell you for sure if you are covered or not. Dealers may just tell you that you aren't to get you to pay... there are a lot of Nalley Acuras out there.
Old Dec 10, 2006 | 02:37 PM
03c0upe's Avatar
1999 tl
i did call a few acura places they say the same thing...is owner link just for american cars or canadian too?
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
