Car turned off while driving..
i was driving along and my car suddenly turned off...this happend before when i tried to start it ..it didnt start on the first turn....now it turned off while driving..it did start up again ....What do guys think is wrong..im at 100,000 KM
It could be caused by many different things.
here's an easy one to check. Do you have another Honda or Acura key on your keyring? If so, another key with the built-in immobilizer feature can interfere with your ignition system. There is a caution about this in the TL owner's manual.
I had stalling problems with my 1999 TL until I removed a Honda key from my key ring.
Bob
Bob
Originally Posted by 03c0upe
ive been readin it could be the IACV or ignition switch...when i start or turn of my car its not as smooth... do i need one of those replaced? or spark plugs
The ignition switch is another possibility. There was actually a recall on the ignition switch for the second generation TLs. My 1999 TL had this replaced before I purchased it. If you're not the original owner of your car, you can call Acura or check the Owner Link to see if your car is covered by the recall.
Spark plugs can be another possibility.
Bob
I did call the Acura dealership with my VIN they said theres is no recall for my car..if i call a someplace else or not?
Bob
where can i register or get the #?
https://www.ahm-ownerlink.com/user_profile.asp
And this is contact info from Acura.com:
BY PHONE
Monday through Friday, 6:00 AM to 5:00 PM Pacific Standard time at the toll-free number (800) 382-2238
Bob
So if my car doesnt start the first time i turn it..it could be the ignition switch?
Here's another thing to look for. If the car doesn't start initially, look for the flashing green key symbol on the dash. If you see that, it might indicate that the immobilizer system is preventing the car from starting.
Good Luck!
Bob
Originally Posted by Bob_F
Yes, it's a possibility.
Good Luck!
Bob
Good Luck!
Bob
the immobilizer keys can be damaged if they get wet or if they get too hot. It might be that your key is acting up. You might want to get a replacement and try that since it's not a bad idea to have a spare anyway. But be aware that the keys are not cheap and that you may need to get it from an Acura dealership.
Search the forum for "spare key" for more information.
Bob
Bob
well i know its not the immobilizer i got the car started if i hold the key ..i towed it to the mech..seems like it has the symtoms of a igntion switch failure...once the ignition switch gets replaced do i need a new set of keys or anything?
i do have a 99 it did stall while driving..and now it wont start at all unless i hold the ignition key at start postion ..i called my local dealer and said im not covered..mechanic so far cant diagose the problem..i crank the key power windows dont work..guessing it is the ignition switch...i need more info on what i need to replace..the whole switch or part of it? one part is 300 and other is 90$
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
