Car shaking occasionally
Old Mar 18, 2016 | 06:21 PM
Ephmasard's Avatar
I recently had a problem with my Acura TL. After driving it all morning, my car suddenly started repeadly shaking, almost as if I had a flat tire. I pulled over to check my tires but they were all fine. The problem hasn't come up since, but I'm still curious as to what it might be. Another occasional problem I've had is my car starting up and slowly the revs drop until it stalls unless I rev it up. Maybe the two problems are related?
Let me know your thoughts! Thanks!
Old Mar 18, 2016 | 06:35 PM
MarcDavidoff's Avatar
It could be a number of things. Any engine lights come mon when this occurred? It could be fuel related, ignition related, or? I'd start with the simple things first. How old are the spark plugs? Air filter?
Old Mar 21, 2016 | 11:58 AM
01tl4tl's Avatar
failing ignition coil, clogged EGR ports, clogged IACV which gets serviced thru bottom of TB while intake manifold is removed from engine for egr system cleaning!
banana13
2G RDX Problems & Fixes
15
Jul 1, 2016 06:25 PM
nore03
May 4, 2016 02:10 PM
Evilocity
Apr 22, 2016 09:33 AM
synth19
Mar 1, 2016 05:43 PM
