Car is shaking...
Old Nov 15, 2006 | 01:53 PM
dnam85's Avatar
Car is shaking...
It started to happen few weeks ago...The sterlingwheel does not shake/vibrate that much but I can feel it it's shaking/vibrating/jerking...(Not too sure how to explain exactly)
This ONLY occurs when going between 40-60km/h at low RPM. (1.5 or 2) I thought it was the rotors and the tire issue but i guess not since i changed the rotors, pads, and tires few days ago.
Should I get the alignment done? any suggestions??
Old Nov 15, 2006 | 02:50 PM
Hitlayers's Avatar
Did you get the new tires balanced? If so then this could be a bent rim issue.
Old Nov 15, 2006 | 04:44 PM
phipark's Avatar
Not Asian
which gear?
Old Nov 16, 2006 | 02:22 AM
dnam85's Avatar
Yes, I got new tires so it's all balanced...and non of my rims are bent...
And. I didn't really check which gear, but i think 3rd... I will double check on that..
Old Nov 16, 2006 | 06:37 AM
fsttyms1's Avatar
Just because you have new tires doesnt mean its balanced Did it do the exact same thing before the new tires? If not try to Rotate the rear tires to the front to see if it goes way.
Old Nov 16, 2006 | 09:33 AM
Hitlayers's Avatar
Old Nov 16, 2006 | 11:25 AM
dnam85's Avatar
when I got new tires, it was balanced and installed. I went to the shop to change my tires. And yes, it did exact same thing before new tires.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
