Car humming
Old Aug 24, 2008 | 02:54 PM
Kobazi's Avatar
Car humming
I have a 2000TL with 105KM. I'm not exactly sure on how to describe this, but about few weeks back my whole car started making this weird humming sound. It feels like the car has this huge weight on it. I guess a better explanation would be if you are driving a manual car and you did not shift to the next gear after reaching a certain speed. This whole issue started when a friend of mine bored the car for a week and started to use a low grade gas. After doing some research on this site, I seafoamed the car but the issue is still happening. Any ideas has to why?????
Old Aug 24, 2008 | 02:57 PM
Kobazi's Avatar
Oh yeah, the car runs fine, I think the issue starts from shifting the 2nd to 3rd gear.
Old Aug 25, 2008 | 10:29 AM
Kobazi's Avatar
Could this be a sign that the transmission is about to go?
Old Aug 25, 2008 | 01:22 PM
fsttyms1's Avatar
Does the sound change with RPM?
Old Aug 25, 2008 | 08:57 PM
Kobazi's Avatar
No it's the same through out. When I pull out of the driveway it's fine but as soon as the second gear hits, it starts, or 2000 RPM.
Old Aug 25, 2008 | 10:29 PM
01tl4tl's Avatar
try this test
at light throttle cruising in D5 at 25 and 35 mph, stand on the gas and stay there.
It should downshift into 2nd and launch forward without hesitation
If it lags catching into gear- revs up and doesnt engage gear right away- thats a trans problem in the making- weak clutches- thats are usual failure point
Old Aug 28, 2008 | 08:07 AM
Kobazi's Avatar
It was able to catch without any problem. Would changing the trans fluid help?
Old Oct 15, 2008 | 08:09 PM
Kobazi's Avatar
I got it fixed ladies and gents.... it was the back rotors
Old Oct 16, 2008 | 04:00 PM
rob-2's Avatar
I was going to say brakes!
Old Oct 16, 2008 | 10:20 PM
totaledTL's Avatar
"Huge weight on it"- sounded like calipers might have been dragging- what was the problem with the rotors?
Old Oct 17, 2008 | 08:09 AM
fsttyms1's Avatar
Shouldnt be anything to do with the rotor, If anything it should be the caliper hanging up on the rotor.
Old Oct 18, 2008 | 11:09 PM
totaledTL's Avatar
That's what I thought- but he reported it was the back rotors....
Old Oct 25, 2008 | 11:06 PM
Kobazi's Avatar
Sorry that was a mistake. Actually it was one of the back bearings (not rotors). When I we took it apart the grease inside was so viscous that they could barely turn. I decided to replace both bearings and the breaks since I was already working on it.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
