Car doesnt start...its really cold outside
Old Dec 21, 2008 | 11:40 PM
ts_vaj's Avatar
Right now I just went to move my car and it wouldnt start, It was weak, so I gave it some gas and it fired up, but if i let off the gas it dies. Battery seems fine, I just replaced it this summer.
This afternoon the car drove just fine. Right now it's nighttime so the temps dropped to -5 degrees.
anyone know what could be wrong?
Old Dec 22, 2008 | 07:31 AM
fsttyms1's Avatar
So it wont stay running unless you give it gas?
Old Dec 22, 2008 | 08:53 AM
ts_vaj's Avatar
Yeah...can you move this to the right forum....I musta clicked something wrong when I created this thread. Sorry.
Old Dec 22, 2008 | 09:13 AM
ts_vaj's Avatar
No CEL, no warning lights. The car starts up fine, no clicking or weakness, it just dies right after it starts up lol.
I have to go to work so I just started it, and held the gas to 1k to keep it alive for about 4-5 minutes and now it's running fine. I guess it had to warm up. The temp is -7 right now.
Does anyone know what could be wrong? It dies when the engine is cold, during extreme cold. Now that it is warmed up it runs fine again. Thanks.
Old Dec 22, 2008 | 01:06 PM
MikePA's Avatar
You might have some water in the gas which turns to ice and blocks the line? Just a guess. If so, some dry gas will fix the problem.
Old Dec 22, 2008 | 04:23 PM
BlackuraTL's Avatar
Broke college grad
My friends got the same problem in his blazer so I'd like to know also what it is.
Old Dec 22, 2008 | 05:18 PM
fsttyms1's Avatar
The IACV may be a little frozen or the TPS sensor may not be reading correct?? throw some heat in the gas and see if it helps.
Old Dec 22, 2008 | 05:47 PM
ts_vaj's Avatar
Thanks for the responses, what do u mean by throw some heat in the gas?
I bought some ISOHEET....Would that be a solution to the gas line possibility? I'm gonna use it anyways
Old Dec 22, 2008 | 07:18 PM
inyong1988's Avatar
could be the start or alternator.
Old Dec 23, 2008 | 09:14 PM
Russell The Love Muscle's Avatar
Starter-Definitely NOT
Alternator-wrong again..
probably the oil is so cold the motor is having a hard time moving it, you should get a engine block heater if the other heat doesn't help and the IACV and TPS are working correctly
Old Dec 26, 2008 | 05:17 AM
YeuEmMaiMai's Avatar
i think it is a sensor problem or a vaccum leak......
there have been a few nights where the temp here was -20 and my CLS started right up even though it took a slightly longer crank time...
just out of curosity is your battery an acura one?
Old Jan 2, 2009 | 09:45 PM
rattmann316's Avatar
an OEM block heater is like 90 bucks or something and is fairly easy to install
Old Jan 2, 2009 | 09:51 PM
Rajca's Avatar
wham bam thank you ma'am
plugged egr port ? carbon build up on spark plugs giving it a week spark ?
HEAT is like some kind of additive that wont let gas freeze. but what ppl dont know is that gas wont freeze.
Old Jan 2, 2009 | 10:56 PM
totaledTL's Avatar
Probl. just prevents any moisture in the fuel lines from freezing, not the gas.
Old Jan 2, 2009 | 10:59 PM
Rajca's Avatar
i remember ppl were mentioning that the 99s were having vapor problems in the fuel line thats connected to the injector.
Old Feb 2, 2009 | 09:58 AM
ATL_nokio's Avatar
03 TL-S
Did you ever figure out what was happening? It doesnt get that cold here but it seems like when its under 30 degrees here, my car has a hard time starting up. When its warm my car doesnt hesitate hardly at all. One morning I could barely get the car to start up and i had to rev the engine to keep it up and running. While driving the car to work that morning, i had a rough idle when i stopped. Once i got to work i turned the car off and turned it back on and of course it started up without any type of hesitation. I just changed the battery last year and actually had it check recently and it was fine. Any thoughts?
Old Feb 2, 2009 | 10:18 AM
ATL_nokio's Avatar
03 TL-S
Oh one other thing....My car is an 03 and is at 108k which i have the TB and water pump/105k service scheduled for next week.
Old Feb 2, 2009 | 10:40 AM
BlackuraTL's Avatar
Broke college grad
This sounds like the reason to me
Old Feb 2, 2009 | 10:55 AM
ATL_nokio's Avatar
03 TL-S
Atlanta doesnt get anywhere near as cold as it does up north so i figured that there would be a lot more people experiencing this if it was the oil being too cold. Is this fairly common?
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
dlknight
Sep 3, 2015 07:54 PM
