Car doesn't crank
Old May 3, 2010 | 01:40 PM
zeeden's Avatar
Car doesn't crank
There seems to be trend recently with cars being unable to start.
My car won't crank. When I try cranking it my electornics start flickering rapidly. Any idea what the culprit is?
Old May 3, 2010 | 06:09 PM
acutee's Avatar
Check your battery or battery cables.
fleetwood250's Avatar
2000 TL- I had a starting problem for months-seemed like it was not getting fuel sometimes. Started getting worse so finally took it to dealer. They replaced the engine computer and fuel pressure regulator. Over $1000. Had a 20% discount card so $833.
Old May 3, 2010 | 09:04 PM
fsttyms1's Avatar
yours sounds like a battery issue.
Old May 4, 2010 | 07:58 AM
dudeinaTL's Avatar
Wow. Could've got a PCM/ECU off eBay for like a hundred bucks. Swap the immobilizer chip from your original ECU and you're on your way!
Old May 28, 2010 | 08:10 AM
measley's Avatar
zeeden, i have the same exact issue, did you get it resolved?
Old May 28, 2010 | 09:21 AM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
Can you jump start it? If yes, then you have a bad battery.
Old May 28, 2010 | 09:29 AM
measley's Avatar
I can get it to start, it jsut takes a couple tries and its really hesistant to start, and i notice the gauges flickering which made me think it was an electrical problem. a couple times my nav has reset. It only happens in the morning, or at the end of the day after its been sitting.
i'm going to go get my battery tested in a little bit. hopefully thats the problem.
Old Jul 26, 2010 | 06:41 PM
Gfaze's Avatar
S E L L
Ignition switch might be going bad.
Old Jul 26, 2010 | 08:06 PM
YeuEmMaiMai's Avatar
starter relay check that
Old Jul 26, 2010 | 08:21 PM
zeeden's Avatar
forgot to update this thread. It was merely a dead battery thanks for all the tips
Old Jul 27, 2010 | 02:49 AM
01tl4tl's Avatar
thats good news!
Seems like most of the time that solves funky electrical--good battery strength!
now that its in- go get the system fully tested for free at parts store
Make sure the alt wasnt hurt when battery quit
tman570
Jun 11, 2019 07:56 AM
tonio
Feb 5, 2019 05:43 PM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
NSolace
Sep 3, 2015 08:14 PM
dlknight
Sep 3, 2015 07:54 PM
