Can't reset SRS light
Old Jun 11, 2014 | 12:01 PM
SuperGreg's Avatar
I jumped the SCS pin to get the cause for my SRS light and it came back as 15-3 (OPDS sensor). Service manual says to reset the code, but I cannot get the light to reset using a jumper on the 2P connector.
I have tried the following:
- Place jumper on 2P connector
- Turn ignition to ON
- SRS light goes out
- Disconnect jumper
- SRS light comes back on
- Reconnect jumper
Then nothing changes, the SRS light remains on and does not go out again as I was expecting. Am I following the procedure correctly?
Old Jun 11, 2014 | 06:25 PM
3.2TLc's Avatar
Check the "DIY" video procedure again for resetting the SRS light. Maybe ya missed something along the way, IDK....but if it did go out and came back on, then ya may have some sort of actual problem. Just try going through the reset again to make sure.
Old Jun 11, 2014 | 06:46 PM
Groovemaster's Avatar
from my understanding, the light will flash 2 times if the system is clear, and 3 if there is still an issue. Chances are you took too long to reset the jumper, I believe you have to do it under 4 seconds...
Old Jun 11, 2014 | 09:31 PM
fsttyms1's Avatar
^ This is why its easier to use 2 separate wires. Its easier than trying to get them back into the connector if you just are able to touch them together.
Old Jun 12, 2014 | 11:33 AM
SuperGreg's Avatar
OK well I'll try again later tonight and see how it goes. Thanks!
Old Jun 15, 2014 | 10:51 PM
SuperGreg's Avatar
I ended up hooking up a switch to the end of two wires and that did the trick. Thanks guys!
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
mugen_kid
Nov 13, 2015 10:38 PM
95legend6speed
Sep 21, 2015 06:40 PM
vbgregg
Sep 11, 2015 05:38 PM
