Camber Problems
Old Apr 27, 2007 | 10:42 AM
AcuraVibes's Avatar
TeAm InSpIrE
Camber Problems
just wondering what should i do? when i look at my acura tl (2000) from the rear , my tires are not straight expecially the right one. it looks more in on the top part of the tire. not as much as the left. what could that be? ppl say it is the camber. what ever that is cause i kinda new that. just wondering if it is even safe to drive seems like my tire is going to fall offf so can some please help me. thank u
Old May 22, 2007 | 07:33 AM
JD TL-S's Avatar
Need rear camber kit. Which one and where to get, I DON'T KNOW. I also need one?
Old May 22, 2007 | 09:54 AM
fsttyms1's Avatar
did you lower it?
Old May 23, 2007 | 04:23 PM
AcuraVibes's Avatar
TeAm InSpIrE
no i didnt lower it.
Old May 23, 2007 | 06:11 PM
fsttyms1's Avatar
Then something is bent or broke. There is No adjustments for camber on the TL without having a camber kit. Id suggest bringing it to a good alignment shop and have them look at the car to see whats wrong
Old May 24, 2007 | 08:14 PM
jizno's Avatar
There seriously is ZERO camber adjustment stock on a TL? WTF?
Old Jun 8, 2007 | 01:40 PM
VTEC11's Avatar
Yes, as is the case with most hondas.
OP, if your camber is off enough that you can see it with your eyeball, something must be broken and a camber kit won't help. Normally, a camber kit only gives you a couple of degrees of adjustment, which isn't something you can really tell by just looking at the tire.
Old Jun 8, 2007 | 11:51 PM
CJITTY's Avatar
Ackniculous One
Sorry, but I have to disagree. I just had my rear camber kit installed and it completely took away that butterfly effect and my rear wheels/tires are straight up and down, instead of bowed in. Then again, I am lowered which adds to the butterfly effect. In his case, it does sound like something is out of whack.
But a camber kit worked wonders for me. Ingalls 38720 rear kit x 2
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
lanechanger
Oct 13, 2015 10:56 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
0opie
Sep 22, 2015 04:15 PM
