a/c problem after high water
Old Oct 17, 2006 | 08:11 AM
ddlens's Avatar
Question a/c problem after high water
I live in Houston and had to drive through some pretty high water yesterday afternoon. After driving through the water, my a/c quit blowing cold air. Any ideas what the problem might be?
Old Oct 17, 2006 | 09:34 AM
fsttyms1's Avatar
Does the compressor kick on?
Old Mar 30, 2011 | 08:34 AM
gregorydavis's Avatar
same problem here
ddlens, I think I'm experiencing the same problem because of high water. How did it play out for you? Thanks in advance!
Old Mar 30, 2011 | 11:09 AM
Karanx7's Avatar
Unregistered Member
Talk about long time readers, first time posters.
Your car can help you with the diagnoses. Turn the car on to (II) accessory mode. Press and hold the Auto button. Press and hold the Off button. With both of these pressed and held, wait for 1 minute. The temperature display should start flashing. Different segments of the "88" will light up. Those segments correspond to different problems.
Can someone pull that diagram from the service manual?
Old Mar 30, 2011 | 11:40 AM
TLer trash's Avatar
Check your fuses, especially the ones that protect the cooling fans. They draw a shitload of amps when they try to circulate water.
Old Mar 30, 2011 | 11:55 AM
01tl4tl's Avatar
fuses was my first thought as well
Old Mar 30, 2011 | 02:53 PM
totaledTL's Avatar
Old Apr 1, 2011 | 08:34 PM
You guys called it. It was a blown fuse. Thanks much for your help!
Old Jul 11, 2011 | 04:42 PM
trell301's Avatar
MANI88
gredorydavis, which fuse was this? i'm having the exact same problem. Went to OC, MD over the wknd and fri night, there was a crazy thunderstorm and i was driving in flooded streets. Sounds like my fuse blew out too. Now A/C Compressor wont turn on.
Can you please specify which fuse was it that you changed? # and location (hood, driver's side or passenger's side)?
Thanks in advance!
trell301's Avatar
MANI88
gregorydavis*
Old Jul 11, 2011 | 04:51 PM
AMUA6's Avatar
ScoobyZINE
Just start pullin em, Trell
pstomps
Feb 20, 2017 03:29 AM
01CLOwner
Oct 9, 2015 01:07 PM
brandnewcolony
Sep 12, 2015 10:39 AM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
