Buying Recomendations
I am thinking of buying an 03 TL type-s with 68k miles for around $8k. What are some things I should look out for when buying to make sure I get a decent car. I read something about blue bolts on the trans, if it doesnt have blue bolts are there any ways to determining the condition of the trans? How about any other common problems? Thanks in advance.
welcome to the forum
this question is asked every week- please scroll thru the main thread list, and read the last 5 pages of tranny failure thread on this section to educate yourself on that drama
8 grand is WAAAAAAAAY too much unless it just had a $1000+ 105k/7 years old service done,
has trans `warranty replaced` in last year or 2,
and comes with a warranty on trans (good luck with all that!)
Meaning- go buy a nice used honda-!!
much as we all love our TL- there are way too many stories on the used ones where you have to spend 3500 for a trans, then brakes need something- thats another 500,,,then....suddenly its a 14grand car!!
For that money Im getting me a Caddy with the trick motor!!
If it's an original trans I wouldn't even consider it.
*edited to add: If you really want a TL then a better bet would be one with 100k-125k miles, recently replaced transmission (last 2-3 years) and 105k/7yr service verified done. If everything else checks out then that's the car I would buy at this point - stay away from anything with 70k-95k miles and no evidence of recently replaced trans.
105k service -
http://john-perry.com/acurazine/docu...aintenance.pdf
(found on main 2gen TL DIY thread - https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/)
timing belt- water pump,,thats a lot of labor for a shop but a tech buddy can whip it out
the rubber belt gets weak with age,, not so much miles,,
if it breaks it takes out the engine with it,,ask buddy about `interferance engines`
a car with low miles still needs all the `time based services`, replace all fluids and the 105 by now
4+ hours or more,,you always do the water pump with the t-belt on this car as its the next part behind the belt,,and its failure is as bad as breaking a belt!!
hard to tell condition unless covers are removed,,even then its the inside of the belt that wears so you cant tell unless its flipped inside out on the workbench~
a tech with experience can whip this job out in less than 1 hour!!
can you just get a rebuild kit if the trans goes or do you have to replace?
2003 ACURA TL S 3.2L 3210cc V6 FI [J32A2] SOHC : Transmission-Automatic : Rebuild Kit Price $276 ATP Part # HM5
Master Repair Kit: Contains Friction and Steel Clutch Plates, Gaskets, Seals, O'Rings, and Sealing Rings.
Trans. code B7WA
![](http://www.rockauto.com/catalog/images/us.gif)
![](http://www.rockauto.com/catalog/images/ca.gif)
6G TLX-S
If the car is still on the original tranny, then the rebuild process includes replacing with a factory revised tranny block which has enlarged and additional oil passage ways, as well as a factory reprogrammed PCM.
The rebuild process is not as simple as just swapping out the failed internals.
80%+ chance for now and eventually 100%.. especially since you joined azine and are concerned
IF you have rebuilt several auto trans before- you might get the TL done at home with only major headaches
acura doesnt do any internal trans work- they remove and replace with unit from warehouse
only certain vins get the update programming/new module,,there is a list
dealer or acura care 1 800 382 2238 x5 can look up car history for you by VIN
there are trans shops everywhere that will rebuild it for somewhere between $1800 and 2500 average
I have a previous co-worker that is a Acura service writer and found it has had no trans work. I looked into getting an extended warranty on it from my dealer and I can get one for about $1400 for an extra 4 years 48k miles that would cover the trans and many other things. If I bought the car I would get that warranty. seems like a better deal than a 4k trans. Any changed opinions on buying the car if I were to have that extended warranty
I dunno, if it were me I would still stay away from buying a used 2gen TL but the warranty certainly makes the deal palatable. I'd see if they would lower the price a bit to compensate for the cost of warranty and also required maintenance items. See if they'll do the whole deal for $8500 out the door ....
Would the warranty cover an Acura replacement transmission or just a rebuild? Rebuild would be in the same faulty case and would likely fail again, sometimes within 30k-40k miles but maybe not depending on the quality of the rebuild, driving habits and maintenance.
I dunno, if it were me I would still stay away from buying a used 2gen TL but the warranty certainly makes the deal palatable. I'd see if they would lower the price a bit to compensate for the cost of warranty and also required maintenance items. See if they'll do the whole deal for $8500 out the door ....![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
If you can make the deal work and you're only keeping it for the life of the warranty then I say go for it. You'll love the car and you can drive it as hard as you want, break the tranny, get it fixed and then sell it. The new/rebuilt tranny will be better when you want to sell it anyway.
Good luck!
Good luck!
I drove the car today. One question... I was in the "auto stick" mode and when I was in first gear it went into 2nd automatically. Is that normal?
navtool.com
31
11-16-2015 08:30 PM
ExcelerateRep
10-14-2015 08:20 AM
navtool.com
09-25-2015 05:15 PM
