Brake Lights not working!
Old Jul 5, 2011 | 12:54 PM
morrisjim's Avatar
Exclamation Brake Lights not working!
On my 2001 TL, the brake lights stopped working suddenly, and as a result the shift lever cannot be moved out of park without override. Here is what I did to troubleshoot so far:
- checked fuses for continuity - STOP (20A) under-hood and Fuse 9 (7.5A) driver's under-dash - both fuses are good.
- checked for power to Brake Pedal Position Switch - WHT/YEL wire has 12v.
- checked for power from Brake Pedal Position Switch - WHT/BLK wire has 12v when brake pedal pressed.
- checked for power to Brake Light Failure Sensor in left taillamp housing - WHT/BLK wire does not have power when brake pedal pressed. When I provided 12v external power to the WHT/BLK wire, all the brake lamps light up.
So, I figure there is an open in the wiring from the Brake Pedal Position Switch to the rear Brake Light Failure Sensor. I understand that this is not a direct connection, and the signal passes through the PCM. Any advice on how to troubleshoot and fix the issue would be greatly appreciated.
The car has over 200k miles, drives great, and has no other issues. It has been "grounded" because of this safety issue, and I would like to get it back to daily driver duty.
Old Jul 5, 2011 | 04:03 PM
my.daily'tl''s Avatar
Always Working In
take out your console. it is the brake switch for the park override. wow i cant remember the name right now!!
when you put your foot on the brake it disengages the "lock" on the shifter. damn whats the name of that? im having a blond moment.
Old Jul 5, 2011 | 04:06 PM
01tl4tl's Avatar
except when the nuetral safety switch is defective
or the brake lights or out
Old Jul 5, 2011 | 04:07 PM
Always Working In
the interlock switch!!!
Old Jul 5, 2011 | 04:09 PM
Always Working In
its probably what 4tl's saying. would explain no brake lights and you checked fuses and brake switch
Old Jul 5, 2011 | 05:29 PM
TLer trash's Avatar
Actually, the wht/blk wire does not pass through the pcm on the way to the brake light failure sensor. After the brake light switch, there's a splice to the anti-lock system, then on to the back of the underdash fuse/relay box. Next there's a splice to the high mount brake light, a splice to the brake light failure sensor and on to the trailer lighting connector in the left rear corner of the trunk.
The shift interlock doesn't appear on the exterior light page, so I'd guess it would be off the abs splice right after the brake light switch.
Good luck!
Old Jul 6, 2011 | 07:35 AM
morrisjim's Avatar
I will check this out - its not getting power in On and Brake pedal pressed.
Old Jul 6, 2011 | 07:40 AM
morrisjim's Avatar
Good luck!
That's very useful info. I will have to start checking for continuity at every splice/connector. In the meantime, I am also thinking of running a wire from the brake light switch to the failure sensor in the trunk to see if it powers up the brake lights when pedal pressed. Advice?
Does the PCM send signal to the shift interlock?
Old Jul 6, 2011 | 08:18 AM
Always Working In
With your foot ptessing brake, you should feel or hear the lock releasing from the shift lever. I think the interlock works mechanically and is not electrical in nature. But dont quote me on that.
Old Jul 6, 2011 | 11:22 AM
morrisjim's Avatar
No power going to the Shift Lock solenoid - it looks like I am loosing power after the brake pedal position switch. How I wish that it was just a faulty brake switch !
Old Jul 6, 2011 | 03:46 PM
morrisjim's Avatar
Thumbs up Issue Located
I followed the WHT/BLK wire leading from the Brake Position Switch and located the issue at Connector O (behind the under-dash fuse box). The wire and terminal seem to have melted causing an open.
Any ideas on how to fix? Should I look for a new connector, and try to splice in all 19 wires?
Old Jul 6, 2011 | 07:13 PM
01tl4tl's Avatar
what about running a splice connection for that wire outside the connector?
and write the NHTSA highway safety with your pics-
this is a big issue and may result in another recall ~
Old Jul 6, 2011 | 09:54 PM
Always Working In
Wow that looks pretty serious!
A full harness may cost bucks!! connector or complete fuse panel may be found in a tl parts car. Check the black market on this site or find a junkyard locally in your area (www.car-part.com)
Old Jul 6, 2011 | 10:21 PM
totaledTL's Avatar
Def. junk yd. run in order. See if there is a Pull-a-Part near you (cheap). It looks like it would be easier to do what 01tl said or barring that cut & inline splice (ea. wire) on either side of the replcmt. connector. Congrats on running down the problem rather than just replacing parts.
Old Jul 7, 2011 | 08:18 AM
morrisjim's Avatar
That's what I have now as a temporary fix. Good idea to send this info to NHTSA - this could be an one-off in my car. I haven't found any threads for the 2G TL with this issue.
Old Jul 7, 2011 | 08:19 AM
morrisjim's Avatar
Exactly what I was thinking - thanks for the link.
Old Jul 7, 2011 | 08:21 AM
morrisjim's Avatar
Thanks - will see what I can get from a junk yard. The troubleshooting definitely took a lot of hours, but no money spent (yet).
Old Jul 7, 2011 | 08:57 AM
01tl4tl's Avatar
if you want just the connector, go to an `auto electric` repair shop-
they have everything or can get it!
Old Jul 7, 2011 | 05:30 PM
TLer trash's Avatar
As long as your "temporary" fix was properly done, [proper gauge wire, good terminals, good solid crimp or solder], I'd leave it alone.
Old Jul 8, 2011 | 06:30 AM
morrisjim's Avatar
I have to work on it this weekend, to do a proper job. I think it originally overheated due to a loose connection, as the voltage and current measurements appear within spec. BTW, Acura's electrical circuit design appears well planned and executed.
Old Jul 8, 2011 | 05:16 PM
TLer trash's Avatar
You're most likely correct in assuming it was a loose connection. If it was excessive amperage draw, the fuse would blow. A basic insulated male/female spade connector set will handle more current than the tiny oe connector will.
Old Jul 28, 2012 | 09:12 AM
Stein's Avatar
Just had the same problem with my TL. Did you ever write to NHTSA? How did you wind up fixing this?
Old May 22, 2013 | 10:56 PM
Cyro22's Avatar
I had a similar problem with my TL. Same symptoms as morrisJim but no burnt connectors. What was worse is that I had voltage to the brake module, indicating that the brake module must be bad. Part way through testing the voltage to the brake module vanished. I ended up finding a break in the black/white wire 12" after the connector in the trunk. I replaced a 24" section of wire and the issue was fixed. NOW about 6 months later the exact same problem has happened. I will post back when I find out what it is this time.
Old May 25, 2013 | 11:00 AM
Cyro22's Avatar
Found the problem 6" ahead of the wire I replaced previously. There were some broken pin sockets in connector C555 located in the LH side of the trunk (pg.22-70). A strange failure. I ty-wrapped the connector to tighten it, which makes it work, and then will bypass the connector when I have more time. Wounded right now so can't crawl into the truck.
Troubleshooting tip: Use a short piece of wood and slide the DS seat fwd to put the brakes on full-time (key in). The center high brake lights will come on. Then in the trunk on the connector that goes into the brake failure module (LH taillight), check for power on 2 wires. Power on YEL (6) wire means main fuses are good. Power on WHT/BR wire (1) means that power is getting there (thought C555) from the brake light switch. That is the wire that I have had all my problems with.
I used: manual 22-155 wiring, 22-138 BL connector, 22-63 22-70 C555.
Old Oct 3, 2013 | 09:17 PM
Cyro22's Avatar
The saga continues. The tywraps worked for 6 months but the tail lights stopped working again along with the LH turn signals. I expected this, sort of. I guess that was the 2nd broken pin inside the connector C555. I am now able to climb into the trunk so I cut off both offending wires on each side of the connector and spliced a wire in between them, using butt splices and heatshrink. The harness is not long enough to just attach the wires together. Using extra wire makes the crimping of the far-side connector wires manageable. Chris.
mada51589
Jan 9, 2025 04:40 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
theinsvnity
Sep 10, 2015 10:22 PM
drewdeezy03
Sep 3, 2015 08:04 PM
