"Brake Light" In Dash-What Does It Mean?
Old Jan 10, 2009 | 04:17 PM
lely09's Avatar
3rd Gear
I have a brake light button that has turned on in my dash next to the check engine light etc. Does anyone know what it means? I have checked all my lights and they seem to all be working fine. Thankss
Old Jan 10, 2009 | 04:21 PM
Rajca's Avatar
wham bam thank you ma'am
check your brake fluid, and make sure that u didnt accidental hit the e brake (aka hand brake but we have it to the left of the brake pedal) and engage it.
Old Jan 10, 2009 | 04:26 PM
medrxman's Avatar
I had that on my wifes 02 TL and it was a tail light bulb.. Have someone stand behind the car while you depress the brake pedal and see what bulb is not lighting
If it were brake fluid the "Brake" would illuminate
It it was a bulb, "Brake Light" would illuminate.
It is easy to replace. Check the manual.
Old Jan 12, 2009 | 11:10 PM
rob-2's Avatar
There are two lights
"BRAKE"
"BRAKE LIGHTS"
If its the one with lights, a bulb is burned out. If its "BRAKE" its either your parking brake or you car thinks you are low on fluid. This might be due to a leak or more commonly the sensor goes.
Old Jan 13, 2009 | 01:20 AM
01tl4tl's Avatar
even the center/3rd brake light bulbs must be working or the system detects an imbalance and alerts you..
Old Jan 13, 2009 | 07:35 PM
maniaC_99's Avatar
...advance...
^^ yep, replaced mine today
Old Jan 21, 2009 | 03:01 PM
syunit's Avatar
have someone step on the brake and look at your brake lights... commonly one of the center mounted brake bulbs (the one in the rear windshield) is out
Old Jan 21, 2009 | 08:24 PM
phipark's Avatar
Not Asian
Could be the float in the brake fluid reservoir. Mine seems to stick when it gets pretty cold out. Take of the cap and slide it around to loosen it up to see if that helps. I've also heard the filter in the bottom of the reservoir may need to be replaced.
Old Jan 21, 2009 | 09:48 PM
fsttyms1's Avatar
Old Jan 25, 2009 | 03:00 PM
GldCrzy's Avatar
have you had your brakes done yet? i had the same thing for awhile and also thought it was just the light. so i took it to midas and they said i needed new pads and resurfacing of the rotors. btw.. i had 60000 miles and never had the brakes done
Old Jan 25, 2009 | 03:12 PM
Rajca's Avatar
we dont have any sensor that tells us that our brake pads are low. they probably replaces pads and resurfaced the rotors and topped up the fluid.
when your pads get low, you lose more fluid in the reservoir bc it fills the lines and calipers bc the pads are low.
Old Jan 26, 2009 | 01:22 AM
ftLauTL's Avatar
Ya....It's an Acura
x2
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
