Both Heated Seats Died
Old Jan 1, 2007 | 10:55 AM
bill r's Avatar
5th Gear
Both of my heated seats died at the exact same time.
So, I know it's not the seats themselves.
It's not the fuses, checked them.
Anybody know what relay controls the heated seats?
Any help would be appriciated.
I got the drivers seat repaired by the dealer once.
Now one kid can't go to college, I'd like to send the other one if I can.
Any help would be appreciated.
Bill
Old Jan 2, 2007 | 06:08 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
welcome to the board bill! i'm at work so i don't have my owner's manual in my hands right now but i believe the relay would be detailed in there if it's a single relay for both. i'll take a look when i get done today but maybe that will help in the meantime.
SSTS
Old Jan 2, 2007 | 07:23 PM
bill r's Avatar
5th Gear
Hi:
Any suggestions you can provide would be helpful.
Thanks.
Old Jan 2, 2007 | 07:34 PM
fsttyms1's Avatar
I dont have the manual by me either but im almost positive that there is a relay on the drivers side in the engine compartment relay box.
Old Jan 10, 2007 | 09:31 AM
bill r's Avatar
5th Gear
Last shot
I thought I'd give this one last shot.
Anybody know anything about the relays used to control the heated seats?
I'd love to buy the relays and pop them in myself, before I have to go to the dealer and get raped with some phony high priced fix.
Old Jan 17, 2007 | 12:23 PM
ESW3's Avatar
3rd Gear
I have the exact same problem Bill R reported (both the driver and the passenger seat warmers died). It's a 2000 3.2 TL, seat heaters rarely used (Seattle doesn't get that cold!) and only 56K miles on the car, and with both of 'em dead simultaneously, it doesn't seem like the heating element should be the problem.
I've never pulled a relay or fuse for the car so would appreciate detailed information about how one goes about replacing the relay (or fuse, or whatever it is). Page # from the manual, replacement part # -- that kind of granular detail is needed for this newbie!
I was quoted $420 to replace the drivers' side seat heater only -- I don't think so -- especially if there's a more elegant solution.
Thanks.
Old Jan 17, 2007 | 12:40 PM
fsttyms1's Avatar
Relays are nothing special. Get the correct relay and pull the old one out and pop the new one in. Its just like replacing a large fuse.
Im not sure of the exact location because i dont have my manual here but its in teh small black relay box behind the master cyl under the hood
Thanks.
First, do your heated seat switches light up?
Old Jan 17, 2007 | 08:40 PM
ESW3's Avatar
3rd Gear
Yes, both driver's and passenger switches illuminate, in both positions (high and low).
Old Jan 18, 2007 | 08:51 PM
MotionEffects's Avatar
Acura TLS are SLOW
Still need it? I have the diagram if you want it. Give me your email address.
Old Jan 21, 2007 | 03:04 PM
ESW3's Avatar
3rd Gear
Hi there, I'd love to have the diagram but I can't figure out for the life of me how to e-mail you privately. I've looked all over the site for options, clicked on your name, etc.
If you can tell me how to e-mail you I'll drop you a line post haste. Thanks again.
Old Jan 21, 2007 | 05:14 PM
bangumandoo's Avatar
i have teh exact same problem and i would really appreciate a diagram too. i had the same problem and couldnt figure out how to email you privately. if you can email me with it i'd appreciate it very much
Old Jan 21, 2007 | 08:40 PM
Acura TLS are SLOW
Inspiretl@gmail.com email me if you need a wiring diagram
Old Jan 21, 2007 | 10:06 PM
bill r's Avatar
5th Gear
Hi Guys:
I have the same problem with email, even though I'm now a member.
I sent you an email message directly.
Hopefully the diagram will help.
I did find a diagram from somewhere that said it showed the relay, but when I pulled it and put in a known good one, I had the same problem.
So, hopefully yours will show the correct one.
Thanks, Bill
Old Jan 22, 2007 | 01:22 PM
Acura TLS are SLOW
heres a wiring diagram.
Old Jan 23, 2007 | 03:24 PM
bill r's Avatar
5th Gear
I have a 99 TL.
Does your diagram still apply exactly to the 99 TL?
I see that the diagram is for 02-03 Type S.
Old Jan 23, 2007 | 05:09 PM
Acura TLS are SLOW
I have a 99 TL.
Yes, they are the same.
Old Jan 23, 2007 | 05:50 PM
trance957's Avatar
driver side heated seat
the driver side seat is not working, but the passanger side is okay.
i checked the fuse and its fine, but i can't find the driver side relay, where is it?
thanks in advance
Old Jan 23, 2007 | 06:20 PM
fsttyms1's Avatar
thanks in advance
just like the above poster i suspect the problem is in the elements.
Yours if the passenger side is working is most likely the heated seat element that needs to be replaced. Its a common problem on the TL
Old Jan 24, 2007 | 06:33 PM
djdonte's Avatar
Yeah mine work sometimes when they want to, and last time i tried them i smelled burning plastic or something so i just dont use them at all. Im lucky though, cause i live in a warm climate.
Theyre one of those things that are easier/less expensive to just say screw it than get it fixed. Although someone on here has a DIY if you do a search
Old Feb 6, 2007 | 01:57 PM
ACTLY's Avatar
ok I also have a problem with my seat warmers on the driver side only the back heats up and on the passenger side only the bottom heats up can someone help me
Old Feb 6, 2007 | 02:54 PM
SwampGas's Avatar
/etc/car
The passenger doesn't have an element for the back.
Old Feb 6, 2007 | 02:55 PM
fsttyms1's Avatar
passenger side only the bottom heats.
Drivers side sounds like you have a bad element.
You will either have to bring it in to be replaced, or to repair it yourself. There is a thread where a member soldiered in a new wire to make it work.
Old Feb 7, 2007 | 07:46 PM
ACTLY's Avatar
oh i didn;t know the passenger didn't have a back heater...thanks for the info i think i'm going to look more into it and see what i can do
Old Feb 7, 2007 | 08:02 PM
fsttyms1's Avatar
Take a look at this thread
https://acurazine.com/forums/showthr...ht=heated+seat
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
