Bolt for CAI
Old Jul 27, 2006 | 12:07 PM
SONNYS99TL's Avatar
Bolt for CAI
Ok so here is my situation and anyone with a V2 CAI can be of assistance. the bolt that hold the CAI in place using that rubber washer is basically gone to S***. Where if at all can I buy a replacement. The rubber part came off at it's base leaving my CAI to rattle when idle. I need to fix this and temporarily I will be using a twist tie (ghetto) to hold it up. Please help
Old Jul 27, 2006 | 03:30 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
the description on aap.org says:
BOLT-WASHER (6X35)
so i would just go to home depot and find a 6mm by 35mm bolt in the hardware section and find a couple of rubber washers there too to use. sounds like you will need two large regular washers (with ~6mm holes) and two rubber washers (with ~6mm holes) to mock up your own bolt assembly. if you tell someone there what you need they should be able to help you out.
SSTS
tsx_boy
Dec 13, 2019 08:33 PM
lanechanger
Oct 13, 2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
h22lude
Sep 27, 2015 06:22 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
