Blown fuses... what ones?!?
Old Mar 24, 2010 | 11:17 PM
jaMezBOI's Avatar
philly flickin'
Exclamation Blown fuses... what ones?!?
Long story short, I have my hood lifted from an 01 MDX IM spacer and I put my car through the carwash when the back of my headlights arnt properly sealed yet. (new set of projectors installed) Blew out the two HID's they dont work anymore. Then my fogs wouldn't turn on. Im running the foglight mod v2. So I pulled out the fuse for the fogs when the car was running and then my VSA, SRS, and CEL come on. Turned off the car turned it back on and the VSA light turned off and only the SRS and CEL are on.
Anybody know what fuses I blew and if the fog lights are blown or is it just the fuse?
Old Mar 25, 2010 | 10:09 AM
MurdaZ's Avatar
not normal if the lights turned on just from taking out the fog light fuse...can u access a scanner?....if not i would say take dome light fuse, or d/c the battery to reset the ecm for 15 min and connect again to see if it reset the cel light, the srs can most likely be fixed/reset with the paper clip trick
Old Mar 25, 2010 | 09:26 PM
jaMezBOI's Avatar
philly flickin'
Yeah, I got the codes cleared today. It was throwing P0420, which is from my cat, and P1705. From what I've read about that code is you can fix it with a relay. As for the SRS whats the paper clip trick? got a link to a DIY for that?
Old Mar 26, 2010 | 10:55 AM
totaledTL's Avatar
DIY sticky: https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
ripit
Sep 26, 2015 06:19 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
polish_pat
Sep 25, 2015 12:24 PM
STC
Sep 23, 2015 04:36 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
