ball joints
Old Aug 28, 2006 | 03:29 PM
amclipper's Avatar
4th Gear
ball joints
Have an 03 TL-P with 13,000 miles. I have noticed a squeal/squeak noise from the front right suspension when the wheel is turned or the body is moved. I figured this was a dry ball joint and was going to grease the ball joints. I noticed that the bj's appear to be sealed units - with no grease fitting or provisions for installing one. A check with the Acura shop manual says very little about the BJ's much less about any maintenance or lubrication - other than a BJ is to be greased BEFORE installation. Doing a search on this board, I see that others may have had a similar problem and the offending BJ's were replaced. Question 1) I presume that these are sealed no maintenance ball joints, 2) that there is no lubrication provision for these units, 3) that 13,000 miles is a short life for a ball joint. Is there a problem with the Acura ball joints, just happen to get a bad BJ, or am I overlooking something?
Old Aug 28, 2006 | 03:55 PM
acurabum's Avatar
a squeal/squeak noise from the front right suspension DOES not mean
is your ball joints !!!! My 2002 tlp does that too and I lubricate the 2 front shock
and the squeal gone **********
Old Aug 28, 2006 | 04:31 PM
amclipper's Avatar
4th Gear
what did you use as a lubricant on the shocks?
Old Aug 28, 2006 | 04:44 PM
phipark's Avatar
Not Asian
You can use WD-40.
Old Aug 28, 2006 | 07:57 PM
fsttyms1's Avatar
in order to grease teh ball joints, they need to be seperated, and the boot pulled off and repacked with grease.
It could be other things, like a sway bar bushing/endlink, or a shock
Old Aug 29, 2006 | 02:03 PM
acurabum's Avatar
I did spray WD-40 and then some anti-rust liquid to the shocks *****
Live in Canada so have to anti-rust the car *********************
Old Aug 30, 2006 | 10:02 PM
amclipper's Avatar
4th Gear
While at the Acura dealership picking up parts, I mentioned the squeal and asked that they check it. After 45 minutes of looking, they said that the right strut had failed, and that they would replace it under warranty. Thanks to everyone for their suggestions and help.
Old Sep 11, 2006 | 11:53 PM
ayrtonsweb's Avatar
4th Gear
ball joint
I had mine replaced in June because in dry weather and driving over bumps it was making noise. It solved the problem for me.
jblessing
Aug 8, 2018 09:43 PM
marcelft
Jul 10, 2018 06:17 PM
Brandle34
Sep 23, 2015 07:20 PM
0opie
Sep 22, 2015 04:15 PM
V-tecAc
Sep 21, 2015 09:25 AM
